Loosening harmonic damper bolt
![Question](https://classicoldsmobile.com/forums/images/icons/icon5.gif)
On my way to replace the camshaft I also removed the heads and intake manifold. After removing the pullies , alternator, power steering, it was time to remove the damper bolt. You know the big one.....100 ft. lb's of torque.....maybe more. After the water pump is out of the way, think I can stuff a rag between the timing chain and sprocket and loosen the bolt that way?
How about using an impact driver on the bolt with my mini sledge to persuade it to come off?
Any other ideas?
joepenoso
Any other ideas?
joepenoso
My crude way is to put a long breaker bar on the socket bring it around to the drivers side frame so it makes contact, then just bump the starter. Presto, the bolt is loose.
Mind you this is just a suggestion, some guys don't feel comfortable doing this.
ps; make sure coil wire is grounded so engine does not start......
Question Loosening harmonic damper bolt
Actually I was thinking of putting one cylinder head back and stuffing soft rope into the cylinder. I think I will try the starter trick 1st in case I can't borrow my neighbours rattle gun.
joepenoso
joepenoso
I've also put 2 long bolts in the 5/16" holes on the front of the damper and wedged a long screwdriver or die-bar between them so that I'm poised to spin the engine clockwise while turning on the bolt counter-clockwise with a 1/2" breaker bar.
It also works in reverse to tighten the bolt back to 160 ft lbs.
