Lead Substitute with 68 heads?
Old Mar 9, 2018 | 06:26 PM
GHOSTOWLGRID's Avatar
I have a 71 olds 455 that I have 68 C heads installed on, the heads are stock as far as I know.
I always assumed from the start that the lead substitute was necessary, but I thought I'd ask.
Do 68 C heads require lead substitute?
What happens if I stopped using it?
Old Mar 9, 2018 | 06:43 PM
Its up to you if you want to use a lead substitute or additive. I've never used any and have seen no ill effects on any of my nor any others here in Texas. People have said that you get valve seat recession but as of yet I have never seen nor heard of any.
Old Mar 9, 2018 | 10:09 PM
Thats good to know.
yah, I heard the same thing, I just wasn't sure if its fact or myth.
Old Mar 10, 2018 | 06:20 AM
I think it depends on how hard the engine is run.
Old Mar 12, 2018 | 05:49 PM
If the engine is run hard, at high rpm consistently, you will eventually have valve seat issues. If the heads are on the car, and you don’t have any problems I’d wait until you do need to pull the heads for other reasons. If it ain’t broke don’t fix it.
Old Mar 12, 2018 | 10:04 PM
VinMichael's Avatar
The way it was explained to me, exhaust valves get red hot. The hot valves microscopically weld themselves to the seat and very gradually and pull away seat material if the seats are not hardened.
Thats why if the car is ran hard there’s a greater chance of running into issues. Hotter conditions + more rpm results in a more likely event of seeing recession.
The next logical step I can think of instead of replacing seats is using softer valves so the seat wins the boxing match. But I don’t know if that’s a thing. Never heard of it talked about.
chrisn0883
Feb 21, 2015 04:03 PM
70Cutrag
Suspension & Handling
Jul 3, 2014 11:10 PM
apachemobile
Feb 5, 2010 04:59 PM
American Lead
Jan 5, 2008 08:39 AM
oldssragtop
Jan 10, 2007 11:54 PM
