L.A. area olds rebuilders?
Old Apr 6, 2015 | 01:51 PM
CuttyShark's Avatar
Searching the internet seems to just find random engine builders that specialize in NEWER cars. I do not have a stinking' Toyota!!
I did locate some rebuilders,but then I see the business reviews on Yahoo and Google and Yelp and they look horrible and dishonest.
The guy I bought my Cutlass from says that when he sent the engine for dismantling that the engine shop STOLE the 455 because it was an unmolested block. He had to get the police to go with him to get the engine back. I do not want to go through that.
Any reputable, classic engine or Olds specilists in the LA area and beyond? I am in Ontario so I can go East or West or South, or even North if its over Mt Baldie.
Old Apr 6, 2015 | 02:14 PM
70cutty's Avatar
Beer Connoisseur
Well you can contact one of our "in house" builder like Mark (cutlassefi here on CO). He built my 463, you can check it out in my signature line.
I highly recommend him. After shopping around and talking to a few well known Olds builders, I decided to go with Mark. No regrets, he is very knowledgeable and he makes sure that everything is 100% , even if it's at his own expense. From start, with sonic checking the block, to the dyno and shipping.
Or there is Bernard Mondello Racing Enterprises
(951) 371-1432
1520 Commerce Street, Unit A
Corona, California
If I had to do it all over again, I would go with Mark....again.
Old Apr 6, 2015 | 02:15 PM
wls559's Avatar
Don't know about LA, I have an excellent machine/build shop (engines and rear ends) up here in the Sacramento area. It's the only place I will take anything after a coulpe of bad experiences with other shops. The owner was a former Olds mechanic. PM me if you want the info.... might be a bit far away!
Bill
Old Apr 6, 2015 | 06:00 PM
oldstata's Avatar
Justin
64rocket is in Sacramento area or close to. I would talk to him he might even help you out as I know he plays with them on the side
I would see who he suggest in your area
Old Apr 7, 2015 | 06:01 AM
CuttyShark's Avatar
(951) 371-1432
Corona, California
OH! Corona is CLOSE to Ontario! Excellent! Thanks guys. Though they might be out of my price range. Mark may be the best option
Old Apr 7, 2015 | 01:52 PM
Das vierundvierundzwei's Avatar
From: San Clemente Ca. OR Downers Grove Il. Depends....
(951) 371-1432
Corona, California
Bernard will definately set you in the right direction, however I do not believe he is building Olds motors anymore (besides heads.), but thats something you should ask him. I went through him for a build I did and he was incredibly helpful as far as parts and assembly as this was my first build.
He would probably be able to get you in contact with someone in the area who can assemble as well.
Old Apr 7, 2015 | 03:42 PM
Seabass152's Avatar
Sac area olds builder
Bill
That may be useful for me later, I'm in Truckee. Can I get that info from you. Thanks
Tony
Old Apr 7, 2015 | 05:31 PM
wls559's Avatar
Tony
Prentice Automotive in Rancho Cordova. The owner is Jerry and the shop number is 916-852-1957. Good prices, knows Olds inside and out but very busy shop its a two man operation, so if your in a rush.... well lets hope not.
Bill
Old Apr 7, 2015 | 05:47 PM
Magna86's Avatar
Full Race Supply in Yucca Valley, CA. They build and race Olds motors.
Old Apr 8, 2015 | 05:33 AM
CuttyShark's Avatar
Hah. so far Yucca Valley and Corona are the closest to LA. All these Northern CA are basically another state sadly.
Old Apr 15, 2015 | 05:31 PM
CuttyShark's Avatar
Just dropped the 4bbl quadrajet off at Carb Shop in Ontario CA. Very nice guys. Randy there took down the specs of the engine I'm building and they do full service and also Dyno test it on a setup at they shop. For more I could have had it recoated. But figure a good cleaning would be enough. Check them out. They are thinking $250. Maybe less. They used to have JET carbs working for them he said. My last new qjet was a Jet stage II and I was very happy with it, he said this rebuilt one would be even better.
Old Apr 16, 2015 | 06:35 PM
Charly9g's Avatar
Hi. I am in the middle of a 455 build and for machining I used Dougan's in Riverside. they have built ALOT of Olds engines for drag boats, Cars, etc. I'm not sure if they will do the complete rebuild or just the machine work but they can surely help. I had great results with them. 951-681-1961. Good luck!
Old Apr 16, 2015 | 07:01 PM
X2 on Dougans
Old Apr 19, 2015 | 02:59 PM
Charly9g's Avatar
Hi Cuttyshark. I just spoke with Bernard Mondello yesterday and he gave me the name of someone who will completely build your engine for you. He also uses dough's for machine work. Try Grant Warner. 951-906-7951. I think he is in the Corona area. Good luck. Bill. WFG4U@aol.com
Old Apr 19, 2015 | 03:00 PM
Charly9g's Avatar
Sorry, Dougans!!
Old Apr 23, 2015 | 07:04 AM
CuttyShark's Avatar
After interviewing all the suggested people I decided on the Yucca Valley Full Race Supply. This guy was the right combo of Knows Olds engines PLUS price quoted for the machine and rebuild. I had enough left over that I let him talk me out of using the J heads and getting the Speedmaster Procomp heads he sells. He picked it up and is dropping off since I'm basically close to his normal parts route.
Old May 1, 2015 | 07:37 AM
h/o guy's Avatar
I wanted to thank this forum and CHARLY9G specifically for suggesting my name as a contact to help CuttyShark with his 455 build. I do work with both Dougans Racing Engines machine shop as well as Bernard Mondello on a regular basis and have always been pleased with the results from both shops for my builds.
It has become a bit humbling to be referred by such highly respected entities in the Olds and performance engine community and I greatly appreciate it.
I did speak with CuttyShark briefly and reviewed some photos of his parts but after offering some build suggestions and general pricing, he chose another shop here in So Cal to assist him with his build. I certainly hope Dave with Full Race Supply who no longer races or participates as part of the Olds community, treats him as fairly as those who are actively part of the Olds community here in So Cal.
Thank you again,
Grant Warner
jankyrre
Sep 15, 2013 08:35 AM
Flye
May 4, 2013 06:22 AM
jensenracing77
Jan 13, 2013 02:19 PM
Cameo White
Oct 24, 2010 04:52 AM
import extermination
Aug 1, 2009 10:09 PM
