Intake swap, headers, and ??
Old Sep 20, 2013 | 02:02 PM
mphyle0927's Avatar
So I have this addiction.....:-) I have this 455 from I think 1972 in my 65 Dynamic and I just cant leave it alone. I have a new Edelbrock carb on it and I want/need to put a new intake on. I have found an Offenhauser for holly style carbs for just shy of $120. Is that a good price? Also I have been reading about block off plates and gaskets and valley pans and I want to make sure I do this right and add performance to the car not detract from it. Also I want good stuff. Which I understand has a lot of opinion built into it, however, is this a good manifold for a stock motor upgrade? What headaches will arise if any? What first timer mistake do I need to avoid?
Also looking into headers. B bodied car and there seems to be little to no room for headers. are there any?
Old Sep 20, 2013 | 02:18 PM
Erinyes's Avatar
B-body cars from this time frame have no good header options. Dual exhaust means using stock dual exhaust manifolds, or reproductions from Thorntons.
As far as the Offy, which manifold is it? Single-plane or dual-plane? You'll likely want to stick with dual-plane, and frankly the Edelbrock Performer is probably the better bet for an engine that is stock.
Old Sep 20, 2013 | 05:20 PM
Erinyes is correct. There are no headers available for you vehicle. The Edelbrock Performer is a popular manifold for BBO; however, Offenhauser makes good manifolds too.
My father (Oldsguy) had an Offenhauser O4B intake on his 69 Delta 88. He bought it from a friend for $50 since it had a stud broken off in it. After an afternoon taking the stud out it worked great. The only problem with the older Offenhauser intakes is that you can't run HEI ignition with some of them. I know the O4B doesn't allow you to run HEI.
Old Sep 20, 2013 | 10:42 PM
mphyle0927's Avatar
do they interfere with the distributor? I have an hei distributor so how do i know what will or wont work?
Old Sep 21, 2013 | 04:05 AM
You can google the part number and see what the installation notes or what others say.
Old Sep 21, 2013 | 07:49 AM
The 1965-70 full size cars are rear steer, meaning that the steering linkage is behind the crossmember. Given the limited market for these cars and the difficulty in fitting headers, no one makes any. Your best bet would be to start with headers for a 1973-74 Olds Omega (also rear steer) and cut and weld to fit.
Old Sep 21, 2013 | 08:57 AM
copper128's Avatar
Lt. Buzzkill (ret.)
Originally Posted by Olds64
...My father (Oldsguy) had an Offenhauser O4B intake ...
O4B is an Edelbrock intake, just FYI.
As for the exhaust, I personally don't think headers are worth the expense/effort in this chassis. I'd recommend the factory dual manifolds and a good 2 1/2" exhaust system.
Old Sep 22, 2013 | 01:04 AM
Oh right. It's been so many years since my dad bought that intake.
drjr56
Nov 15, 2012 07:20 PM
olds34dude
Apr 18, 2012 06:21 PM
Wyze
Mar 18, 2012 01:59 PM
svnt442
Jul 17, 2011 04:43 PM
martine
Feb 13, 2007 11:57 AM
