Intake manifolds
Old Sep 5, 2007 | 08:43 PM
FL1970442's Avatar
Intake manifolds
Hello, I have an original 70 442 convertible with it's original 455.
I sold it a number of years ago, and recently bought it back.
The guy stuck a mondello high rise intake, & a holley 850 carb on it.
It has a 3200 stall, and a 110 degree comp roller race cam.
Question, I'd like to put the original intake back on. Other than some
h.p. loss, will I have other problems?
Old Sep 6, 2007 | 05:27 AM
If you go back to the original intake then you should put a stock torque converter and carb into it as well. I wouldn't want a 3200 stall in my car if everything else was stock. You might want to ask him if he changed the cam as well.
Old Sep 8, 2007 | 05:46 PM
$tryker's Avatar
Seems you may have low vacuum at idle for the power brakes with that set up. I agree with Olds64, the stock converter would better suit a stock intake. Personally, I would go with Crane cam and a lobe centerline around 114. If you decide to go back to the stock intake and are willing to unload the Mondello top half, then send a PM. I would be interested. Other then that, it still can be street driven, it just depends on your preference. Good luck!
Old Sep 11, 2007 | 05:32 AM
FL1970442's Avatar
Thanks for the advice
Crazy88
Apr 9, 2019 06:55 AM
svnt442
Jul 17, 2011 04:43 PM
Prsabordo
Apr 5, 2010 10:32 PM
oldzy
Mar 3, 2010 11:53 AM
joewit
Ninety-Eight
Oct 23, 2006 05:11 PM
