Intake Manifold Gasket
Old Dec 16, 2021 | 10:28 AM
oldguy442's Avatar
I'm finishing the build on my 455. I'm using an original W30 intake. I furnished my builder a steel valley pan gasket, but he is suggesting I locate a composite gasket with a steel liner. I'm striking out on finding it. Any comments or suggestions from those of you who have already been down this road?
Old Dec 16, 2021 | 10:38 AM
Every W30 came from the factory with the steel "turkey tray" intake gasket. Why does your engine builder think he knows more than the people who designed the engine in the first place?
Old Dec 16, 2021 | 12:25 PM
Well I have never heard of one for an Olds engine. If they do exist, I haven't heard about them.
Old Dec 16, 2021 | 10:17 PM
Mr Gasket 404, fel pro also offers one.
The turkey tray gasket keeps got oil off the bottom of the manifold, and keeps the hot intake from cooking the oil that splashes up on the exhaust crossover.
As Joe mentioned, every Olds engine with a factory aluminum manifold used the turkey tray style gasket. I will also say the composite gasket is more forgiving of sloppy machine work.
If everything is machined correctly (flat, square, nothing milled excessively) the turkey tray should work fine.
Old Dec 17, 2021 | 06:02 AM
69 Hurst's Avatar
Olds Fanatic
Fel-Pro MS96004
Old Dec 30, 2021 | 03:20 AM
6844268's Avatar
was this tray on all engines including the tri carb for '66/'67?
Old Dec 30, 2021 | 06:33 AM
67OAI's Avatar
Old(s)GuysRule
Yes to 6844268 (no factory tri carb in 1967 Oldsmobiles), and also a version of it on the low deck 330/350 motors! It's all I have ever used on any Olds motor be it race or street oriented.
Old Dec 30, 2021 | 06:59 AM
The Olds 330 also used a 2 piece stamped steel intake set, FEL-PRO MS99471,for the engines with a bolt in valley tray.
Old Dec 30, 2021 | 03:21 PM
CANADIANOLDS's Avatar
It’s better to use the turkey tray with the stock aluminum intake as far as I’m concerned.
the casting is very thin and will not tolerate a thick fiber gasket that will distort the intake when it’s torqued.
the problem is many of the factory intakes are cracked and twisted out of shape and have been eaten away at the water passages.
Best way to fit the intake is sit it on the engine with no gasket to see if it’s sitting flat along both heads, front to back with no rocking.
if it’s ok, your good to go with the turkey tray.
if it isn’t, you can’t tweek the intake a bit by using shims and torquing it down to twist it back to being flat…if it’s been welded like so many , you definitely need to check it on the heads first without a gasket
Oldssupreme
Jul 25, 2016 09:47 AM
JpMotorsports
Mar 26, 2015 07:10 AM
harleyrules
May 4, 2011 09:33 PM
jensenracing77
Oct 22, 2010 11:02 AM
import extermination
Jul 23, 2010 05:41 AM
