Intake gaskets...
Old Apr 29, 2012 | 04:07 PM
442_Mustang's Avatar
Intake gaskets...
I had a problem with my intake gaskets. Edelbrock heads, and intake. Any ideas why this happened and how to prevent this? I got new felpros again but the cheap mr gaskets were recommended . Either way i just dont want any more problems. Help????!!!!????
Lol dang. I cant post a picture from my phone. Well, they split and pushed out and gave a nasty acuum leak. I will try to post a pic some other way....
Old Apr 29, 2012 | 05:10 PM
Rickman48's Avatar
You must've had a backfire to blow them out!
You did re-torque again after warming the motor, didn't you?
Lock washers??
Virgin aluminium expands and contracts a lot!
Old Apr 29, 2012 | 05:17 PM
No, it has never backfired. Not even when we dynoed it. I did retighten them after we dynoed it. The gaskets are spilt at the bolt holes and at the top of the port and pushed out. I have one of those little K and N breathers on both rocker covers too so there shouldnt be pressure inside the engine. Maybe i should have stayed on the torquing the bolts more but none were really loose when i pulled them. Wish i could post pix from my phone to this page. Can anyone tell me how to post from the Iphone to this site?
Old Apr 30, 2012 | 04:12 AM
http://sphotos.xx.fbcdn.net/hphotos-...89225402_n.jpg
I hope this works.
Old Apr 30, 2012 | 05:25 AM
TripDeuces's Avatar
Is the manifold straight? What did you torque the bolts to?
Old Apr 30, 2012 | 05:52 AM
I assumed it was straight. It was new. I will have to check. I dont know what they were origionally torqued to. My engine guy did it and did the retorque and check valve lash after dyno. It looks like that silver rtv kinda shrunk the gasket and pulled it but that seems kinda hard to believe
Old Apr 30, 2012 | 05:54 AM
Rickman48's Avatar
And in what sequence were they torqued??
Supposed to be inside out.
Old Apr 30, 2012 | 06:04 AM
No idea but im pretty sure he did it correctly.
Old Apr 30, 2012 | 06:11 AM
Tony72Cutlass'S''s Avatar
Weren't the stock gaskets cork? I think that's what was used on my car, i have the edelbrock performer manifold and it hasn't blown out yet.
I can check this evening though. I'd like to eventually rebuild my engine/heads so this is going to be good information.
Old Apr 30, 2012 | 06:33 AM
TripDeuces's Avatar
Oldsmobile intakes are outside in.
http://wildaboutcarsonline.com/membe...Section_6B.pdf
See page 7
Old Apr 30, 2012 | 06:36 AM
It was possibly over torqued. Usually it pushes out the end seals. Change them and see what happens.
Old Apr 30, 2012 | 08:11 AM
Hmmm... I wonder if its a factor in the order he torqued them . He is a Mopar and Chevy guy... Dayumm... Very interesting. Stupid gasket set dont have any info sheet.
Thank you!!! I will have to look into that...
Old Apr 30, 2012 | 08:27 AM
coppercutlass's Avatar
Chevy budget Olds powered
what is about misalignment ? I have had water pump gaskets do the same thing when not alined right .
Old Apr 30, 2012 | 09:54 AM
Boy, I've never had this happen with a stock-style turkey tray gasket.
Just sayin'...
Old Apr 30, 2012 | 10:34 AM
Just sayin'...
Lol, that would be tuff to do to the almost indestructable turkey tray. However, since the turkey tray from fel-pro is misstamped, I've seen other issues along the way!
Old Apr 30, 2012 | 11:30 AM
70cutlass831guy's Avatar
My valley trey style gasket leaked. I had to reseal it with individual gaskets.
Old Apr 30, 2012 | 11:37 AM
scooter123's Avatar
here you go....lots of help from guys when I did mine.....and I tossed the end gaskets and just used the copper rvt...and all is great!!
https://classicoldsmobile.com/forums...nd-tricks.html
Old Apr 30, 2012 | 01:21 PM
Well im going to use the ultra blue on the end seals . I wonder if torquing them from the inside out was the problem
Old Apr 30, 2012 | 04:07 PM
Nufo's Avatar
that doesn't look like a gasket failure or a torque issue. that looks like the gasket was NOT in it's correct place once the manifold was set onto the engine. the manifold moved the gasket and it was torqued down in that position. IMHO...
Old Apr 30, 2012 | 04:25 PM
There was some sort of spray gasket adhesive used to glue the gasket down. I wiped that all clean with laquer thinner... Trouble is, the guy that built my engine is in jail right now for supposedly raping a young girl so i don't forsee any future contact with him.... Im just trying to figure out what happened so it don't happen again...
Stevec
Mar 15, 2012 01:19 PM
don_69sbo
Sep 5, 2011 01:35 PM
jag1886
Jan 16, 2011 08:41 AM
rtpassini
Nov 20, 2010 05:58 AM
Kidcutty
Mar 25, 2010 09:29 PM
