Intake gasket question
Old March 20th, 2015 | 11:29 AM
  #41
Originally Posted by jdclemons
I have a question. Is the valley pan a gasket itself or not. I just install the pan or do you use gaskets too.
As stated above, it is a gasket. There are stamped-in ridges around all of the ports that get compressed when the intake is torqued down. This is what creates the seal and why the valley pan can't be reused.
Old March 20th, 2015 | 02:41 PM
  #42
Oldsragger's Avatar
Mine was like that. it have been re-use before too, cause i can see the lines/mark on the aluminum intake from the vally/turkey pan gasket, when it was re-used it have sealent around all holes and on both sides when i took it of whit the iron intake installed.
Old March 22nd, 2015 | 01:20 PM
  #43
Oldsragger's Avatar
Full re-usable now, with new rtv / oil/gasoline sealer. Took a vacum clean after over all holes and in the block
Bobac455
December 4th, 2013 09:23 AM
aussiemobile
February 15th, 2013 07:31 AM
harry k
November 21st, 2012 08:54 AM
dallasite21
June 20th, 2010 05:37 AM
Sixoh
August 8th, 2006 05:11 AM
Quick Reply: Intake gasket question
