Inconsistent cylinder temperature readings
Old Sep 14, 2017 | 04:16 PM
oldschool85's Avatar
Freshly Rebuilt 455 engine with new camshaft .
Symptoms: Lean pop off idle. ( Not sure if related)
Cylinders #2 and #3 have different temperature readings at cylinder head using heat infrared test gun.
1-370, 3-220, 5-380,7-390
2-185,4-365,6-390,8-385
I double checked the following:
Firing order- Good
Timing- Correct
Plugs and Ignition Wires- Good
Compression test - Good
Vacuum Leaks- None
What am I missing?
Old Sep 14, 2017 | 04:29 PM
So a rich mixture would cause lower cylinder temperatures and a lean mixture would cause higher cylinder temperatures.
I have never tried to measure the temperature of a cylinder head.
Old Sep 14, 2017 | 04:30 PM
cutlassefi's Avatar
Manifolds or headers?
60193W30's Avatar
Did you take a reading at the headers?
Old Sep 14, 2017 | 04:31 PM
Headers.
Old Sep 14, 2017 | 04:33 PM
Readings at headers are:
1-215,3-208,5-235,7-207
2-136,4-276,6-430,8-430
Old Sep 14, 2017 | 04:37 PM
60193W30's Avatar
What intake are you running? Carb?
Old Sep 14, 2017 | 04:40 PM
Stock intake with pelnum divider milled. Rochester Quadrajet
Old Sep 14, 2017 | 05:08 PM
cutlassefi's Avatar
My guess would be you have a vacuum leak on cyl's 6 and 8 to start with.
Old Sep 14, 2017 | 05:31 PM
Old Sep 14, 2017 | 05:56 PM
47 Convertible's Avatar
FWIW I'm thinking you have no combustion or intermittent combustion in 2 and 3 despite having new plugs, wires etc. That might be the cause of low heat readings. Even with no combustion or intermittent combustion some heat will transfer through the block possibly accounting for the low readings
Its not unknown for new plugs to be bad. When I rebuilt my 455 it idled poorly. Took me a while to check the same things you did and finally pulled the plugs. One plug was grossly fouled. replaced it with another new plug. End of problems.
Jerry
Old Sep 14, 2017 | 06:05 PM
Jerry
I changed the plugs twice
What can be the cause of intermittent or no
combustion ?
Old Sep 14, 2017 | 07:54 PM
lshlsh2's Avatar
71 cutlass convertible
Distributor bad? points or hei?
Old Sep 14, 2017 | 08:08 PM
If you are getting good spark in all cylinders I'm at a loss to explain why the low temps in 2 and 3. Maybe something mechanical? Cutlass EFI had good advice with regard to checking for vacuum leak on #6 and #8
Have you asked your engine rebuilder these same questions? What do they say?
Jerry
Old Sep 14, 2017 | 08:13 PM
Distributor was checked and I tried a known good one- same issue.
We assembled engine - did not talked to any engine builders yet
Old Sep 15, 2017 | 11:58 AM
Water in the combustion chamber would decrease the temperature.
Old Sep 15, 2017 | 06:26 PM
shiftbyear's Avatar
sometimes when the valves and seats are ground it requires adjustable rockers because the valves won't seat, this could also cause a pop. a vacuum gauge may verify this problem, good luck
File Type: gif
Old Sep 15, 2017 | 10:58 PM
Firewalker's Avatar
He said compression good, and I assume he meant he checked all of them, and it shouldn't be good I would think, with a valve leak with it off the seat.
Old Sep 19, 2017 | 05:36 PM
Vacuum readings steady at 15 Inches
Old Oct 3, 2017 | 05:48 AM
74sprint's Avatar
I agree with Cutlassefi because I had the same problem as you. I tried everything I could think of to find out why. I did find the problem after swapping in a Torker intake. The stock intake manifolds are bad for cracking on the bottom side, mine had 3 hair line cracks. Also don't take readings of the head because the water flow will confuse you. Always take readings of the exhaust manifolds or beater yet the header pipes.
Ray
Old Oct 3, 2017 | 06:14 AM
Problem was the intake gaskets. Fixed- Vacuum now steady at 17-18 inches
Old Oct 3, 2017 | 06:23 AM
Firewalker's Avatar
That's great!!!
ToronadoGuyDenver
Sep 8, 2017 05:04 PM
grmchne78
Jun 21, 2017 04:38 AM
68vert
Jul 21, 2015 07:51 PM
Benton Quest
Jul 27, 2012 07:03 AM
DAN76
Jul 29, 2009 02:36 PM
