Oil pump pickup installation
Old Sep 30, 2017 | 08:18 AM
RROLDSX's Avatar
I believe my engine failed due to the pickup pivoting down. Are these supposed to be welded once positioned?
Old Sep 30, 2017 | 08:22 AM
ELY442's Avatar
Yes, once it is position on the right angle, have a few tack welds or buy the "bolt on" type like I did on Rock Auto.
Old Sep 30, 2017 | 01:09 PM
RROLDSX's Avatar
Thanks Ely442.
Old Sep 30, 2017 | 03:33 PM
RetroRanger's Avatar
72 Olds CS
I tack welded mine once in place but I saw a retainer that could be purchased to be sure the pick up stayed in place
Old Sep 30, 2017 | 03:36 PM
72 Olds CS
http://www.jegs.com/i/JEGS-Performan...23620/10002/-1
Old Sep 30, 2017 | 06:06 PM
RROLDSX's Avatar
It looks like the bolt on type are for the high flow pumps. Unfortunately I just purchased the standard volume pump so I will be spot welding the pickup once properly positioned.
Thanks for all the input.
Randy
Old Oct 3, 2017 | 04:04 AM
BillK's Avatar
Randy
Randy,
If you are going to weld it make sure to either TIG weld it with a proper rod for cast iron or braze it. I have seen guys try to MIG weld them and the weld almost always cracks.
Also if you braze it make sure and take the relief valve out first so the heat does not affect the spring.
Old Oct 3, 2017 | 06:34 AM
edzolz's Avatar
Have it TIG welded using silicone bronze rod. It doesn't require enough heat to melt the base metal and fuses the two together very securely.
Old Oct 4, 2017 | 12:48 AM
cdrod's Avatar
Rodney
RetroRanger:
Jegs website says fits Chevy engines, will this work on an Oldsmobile?
Old Oct 4, 2017 | 04:10 AM
BillK's Avatar
Originally Posted by cdrod
RetroRanger:
No, it is made for Small Block Chevy pumps
Old Oct 4, 2017 | 03:14 PM
RROLDSX's Avatar
I'm thinking after all this I may just bite the bullet and go for a high volume pump with a bolt on pickup. Thanks for all the input.
Randy
csouth
Aug 26, 2012 06:16 PM
RAMBOW
Feb 25, 2012 11:31 AM
88hurstolds
Oct 6, 2011 08:26 PM
1FSTLS1
Jan 16, 2011 02:32 PM
cts-v
May 26, 2009 06:52 PM
