I'm install my mini starter
Old Dec 10, 2015 | 02:55 PM
sealw98's Avatar
I'm installing my mini starter
When in stalling the Mini Starter I keep hitting this "ear" piece off the side of the block just above the oil dip stick area, was wondering if I could shave this piece off and what is it's function, thanks for any help.
File Type: jpeg
Old Dec 10, 2015 | 03:10 PM
sealw98's Avatar
2nd photo
2nd photo wouldn't load on first post
File Type: jpeg
Old Dec 10, 2015 | 03:17 PM
wr1970's Avatar
What brand of mini starter are you using and what motor
Old Dec 10, 2015 | 03:22 PM
Octania's Avatar
That's for the support / ground / torque strap for the OEM starter. See the assembly manual for an illustration. You don't neeeeeeeeeed it, no.
Rather than alter the block permanently, could you maybe clock the starter to a new orientation?
Old Dec 10, 2015 | 03:41 PM
sealw98's Avatar
The starter is
olds 455 The starter is the Tuff stuff Performance 6586b, I have tried to clock the starter but there isn't any setting that will fit, unless I add like 1/2" spacer in between the mounting plate and the block. Thanks Octania.
Old Dec 10, 2015 | 03:47 PM
Shiny... I'd do what Trip suggested after checking to make sure the mount isn't oil soaked.
Old Dec 10, 2015 | 05:57 PM
RetroRanger's Avatar
72 Olds CS
is it the right starter for olds ? I think a lot of guys here run the powermaster mini starter....mine bolted right up no interference
the summit page lists yours for chevy and poncho
power master
http://www.summitracing.com/parts/pw...ss?prefilter=1
Old Dec 10, 2015 | 08:05 PM
wr1970's Avatar
power master
Exactly why i ask what brand and motor!I agree go powermaster problem solved!
Old Dec 11, 2015 | 07:58 AM
sealw98's Avatar
olds 455 It's the tuff stuff 6586b which is suppose to be for the Buick Olds Pontiac cars. No matter how I adjust it the solenoid bumps against that ear piece. I see some on eBay for under $150 was wondering if I should just get a completely different one. I think they are called "Snap ez start" they seem to have a lot more adjustments versus the one I have. Just confused.
Old Dec 11, 2015 | 08:39 AM
wr1970's Avatar
Well you can try any brand of mini starter you want but consider this!You have been advised on a brand that works with no issues.That brand is powermaster and while you may and i say may find a cheaper starter to work. Why not just get one that works and is proven not by one guy but two.I have three powermasters on three engines no fitting problem.Mine was a 9510 for a 455 a body. Enough said! You choose if you want to follow a path of trial and error till you find one that works.
Old Dec 11, 2015 | 11:13 AM
70cutty's Avatar
Beer Connoisseur
Powermaster is the way to go.
Old Dec 11, 2015 | 03:52 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I ran the Power master starter that looked exactly like that one on the Olds 350 in the now burnt Olds powered 4x4. Cleared fine and cost $127 listed for a SBC. Does the 455 have that boss only?
Old Dec 11, 2015 | 04:11 PM
biggus's Avatar
I've got the 9510, bolted on no problem. In fact it suprised me how easy it was to install.
Old Dec 11, 2015 | 04:38 PM
Cincinnati Rick's Avatar
Neeley,
I just ordered a 9610 from Summit yesterday. It looks like it is recommended up to a 12.0:1 compression where as the 9510 is good up to 18.0:1. I have a 455 with 10.0:1 compression. I'm hoping there's no fitment issues.Any thoughts? Sorry Seal for sneaking in on your thread.
Rick
Old Dec 11, 2015 | 05:06 PM
wr1970's Avatar
Originally Posted by Cincinnati Rick
Neeley,
Rick
No reason to think you have any issues Rick i think both are good.Back to the op thread.
Old Dec 12, 2015 | 03:10 PM
72 Olds CS
I've got the 9610 no fitment issues olds bbo 455
Old Dec 14, 2015 | 07:40 PM
sealw98's Avatar
Thanks for all the help, I put the factory back in and will order the correct one, can always count on you guys for the best advice, Happy Holidays to all.
Oldsmaniac
Jun 4, 2013 01:16 PM
STLCRZY
Dec 17, 2012 12:47 PM
don_69sbo
Aug 21, 2011 06:14 PM
rhaberm
Apr 19, 2011 09:58 AM
scott71
Mar 22, 2011 12:19 PM
