Ignition setup
Old October 11th, 2013 | 01:18 AM
Dutch455's Avatar
Ignition setup
Hi guys,
i'm thinking about getting a whole new ignition setup for my 71 455,
but when i look at the Summit site i see a lot of different products.
What are you guys using?
My mind goes out to a HEI ignition but in that case, do i need the MSD ignition controller box or the MSD blaster ignition coils, or both?
And which Spark wire set is best to use?
Thanks in advance!
Pieter/Dutch455
Old October 11th, 2013 | 06:04 AM
rjohnson442's Avatar
Mr. Johnson
You don't need a controll box to run an HEI if you want to upgrade from points. A stock (or stock type)Olds HEI Dizzy will have the Coil on top of the rotor cap. Aftermarket ones you can get with external coils an put it wherever you wan't. If you do decide to get a MSD down the road just know that You can not run Solid Core Spark Plug Wires with an MSD box.
Old October 11th, 2013 | 06:13 AM
What do you have now, and why do you want to change it?
Old October 11th, 2013 | 12:15 PM
tmaleck's Avatar
Originally Posted by Dutch455
Hi guys,
Thanks in advance!
Pieter/Dutch455
I'm using a Mallory Unilite with a Flamethower external coil. It has an Accel spiral core wire set. No external control box needed and it fits older engine and manifold combinations. 9.5 degrees initial advance.
Tim
Old October 11th, 2013 | 09:23 PM
Originally Posted by mdchanic
what do you have now, and why do you want to change it?
- eric
x2?
Eightupman
Brakes/Hydraulic Systems
July 12th, 2007 12:45 PM
Kennybill
May 10th, 2007 12:52 PM
snowri
March 29th, 2006 04:36 AM
Kennybill
January 12th, 2006 05:31 AM
anthonysteve38
December 11th, 2004 11:47 AM
Quick Reply: Ignition setup
