Ignition setup
Old Oct 11, 2013 | 01:18 AM
Dutch455's Avatar
Ignition setup
Hi guys,
i'm thinking about getting a whole new ignition setup for my 71 455,
but when i look at the Summit site i see a lot of different products.
What are you guys using?
My mind goes out to a HEI ignition but in that case, do i need the MSD ignition controller box or the MSD blaster ignition coils, or both?
And which Spark wire set is best to use?
Thanks in advance!
Pieter/Dutch455
Old Oct 11, 2013 | 06:04 AM
rjohnson442's Avatar
Mr. Johnson
You don't need a controll box to run an HEI if you want to upgrade from points. A stock (or stock type)Olds HEI Dizzy will have the Coil on top of the rotor cap. Aftermarket ones you can get with external coils an put it wherever you wan't. If you do decide to get a MSD down the road just know that You can not run Solid Core Spark Plug Wires with an MSD box.
Old Oct 11, 2013 | 06:13 AM
What do you have now, and why do you want to change it?
Old Oct 11, 2013 | 12:15 PM
tmaleck's Avatar
Originally Posted by Dutch455
Hi guys,
Thanks in advance!
Pieter/Dutch455
I'm using a Mallory Unilite with a Flamethower external coil. It has an Accel spiral core wire set. No external control box needed and it fits older engine and manifold combinations. 9.5 degrees initial advance.
Tim
Old Oct 11, 2013 | 09:23 PM
Originally Posted by mdchanic
what do you have now, and why do you want to change it?
- eric
x2?
OldsMotion
Brakes/Hydraulic Systems
Jul 12, 2007 12:45 PM
Kennybill
May 10, 2007 12:52 PM
snowri
Mar 29, 2006 04:36 AM
Kennybill
Jan 12, 2006 05:31 AM
anthonysteve38
Dec 11, 2004 11:47 AM
