Ignition Box bad?
Old Nov 26, 2010 | 06:31 PM
sicky olds's Avatar
NôôB
Ignition Box bad?
I think my MSD ignition box (i believe is the name) is going bad. Not sure where i should post it so mods please move to other location if this is wrong.
Symptoms:
Sounds like the starter was going bad but it would jump just fine (battery brand new also)
Today i had it out and then when i started it it sounded like it was slowly turning over like a dying battery. i let it sit for a little then i started it up and it sounded like a .22 went off out of my exhaust.
Solution:
1.) the ignition box
2.) the starter
3.) not timed right (just had it and the carb tuned)
what you guys think?
Old Nov 26, 2010 | 07:10 PM
cutlassefi's Avatar
Symptoms:
Solution:
2.) the starter
Box quits working when you have less than about 10.5 volts so if it''s slow to crank you could have low bat voltage.
Easy way to check the box is, take the white wire and touch it to ground then pull it away. Every time you do that it should fire your coil, if not it's probably bad.
Old Nov 26, 2010 | 07:25 PM
sicky olds's Avatar
NôôB
total noob question but which one is the white wire lol
Old Nov 26, 2010 | 07:54 PM
cutlassefi's Avatar
The white one
Old Nov 26, 2010 | 08:28 PM
Texas Jim's Avatar
Texas Jim
the white one
lol!!!
Old Dec 10, 2010 | 03:42 PM
skryla's Avatar
Pull your coil wire. If cranking normal, then you have a timing issue.
jfb
Jun 25, 2015 04:50 PM
odddoylerules
Apr 21, 2014 07:54 AM
airmale
Nov 13, 2013 11:15 AM
csouth
Aug 29, 2013 08:35 PM
SMOKEYMTNKUSTOMS
Mar 29, 2006 04:42 AM
