I need of help for 425 engine
Had the engine rebuilt to try to get rid of the pinging but it’s still pinging so I change the camshaft and it still pinging do anyone have any answers to what I need to do to get rid of the ping
Welcome. I'm afraid we'll need a lot more info than that to provide a useful answer. What were the rebuild specs? What pistons? What heads? Were they milled? What head gasket? What cam? What distributor? What is the initial timing? What is the advance curve? When does it ping - under heavy throttle, part throttle, light loads? What carb? Do the plugs look lean?
There are a lot more learned guys here than me and they're spot on with their questions, but I'd start by getting some octane booster and dump a bottle or two in the tank just to see if that helped.
If octane booster helps, at least you know the engine can run without pinging, but that stuff adds up fast at $10/bottle or so.
Next try turning the timing back on the distributor. Looking at it from the top, turn it counter-clockwise. Just go incrementally one degree or 2, then drive it. Be aware that this may cause the engine to run a bit warmer.
I'm guessing you are either 10.25 :1 or 10.50:1 compression ratio which requires high octane gas. In my experience even 9.00:1 doesn't like regular gas from this era.
This is key, and as has also been posted octane boosters are a must. Assuming you want to get pinging reduced without going into engine again. With that said Lucas 3X booster works well for me ! I've also been told Royal Purple Max Boost is phenomenal but i have never tried. Keep in mind the booster will need to be added every tank full if you are high compression and stock timing for best results.
I can’t tell you what they put in there they gave me a piece of paperwork 40 pistons 10 rods10 Main Engine master kit number GK 424 Still was pinging talk to Montebello twister they told me to get a 45° cam which I put in still has the ping also what is the temperature should the engine run at i’ll try the octane booster to see if that helps it just doesn’t seem like I can get it on the correct time I have a 600 holly carburetor in it
[QUOTE=Charlie Jones;1199321][QUOTE=Gary Ward;1199284]talk to Montebello twister they told me to get a 45° cam which I put in still has the ping
Mondello Twister........UGH !!!!!!!!!!
I have a 1966 Toronado with a 425 and I don't have any problems and I run it on 93 octane pump gas. It has the original Quadrajet and the engine has never been apart.
The car painter loves driving my "Toro". He wants to finish so we can take it out on the street and SMOKE the tires (tire).
Mondello Twister ? That may explain a lot .
Thanks a lot Joe I appreciate all the information I restored a 1955 Chevy truck that was my dad and he had put the 425 engine in it and I was just trying to keep it the same way had the engine rebuilt and put it back together and now trying to dial it in and can’t get it to.
Hey Joe I Disconnected the vacuum advance on my distributor and a truck ran great had plenty of power but when I try to step on it it started to ping then once I got off the gas pedal it stopped could it be that I have the wrong distributor in here
Is that driving at speed or extended idling. With or without a/c? Either way that's a bit high. Did you get your pinging under control, and how did you do it? If you retarded the timing too much that could cause an engine to run hotter.
Do not have ac/ I kept messing with the timing and I also put octane booster in it but what I did that I think helped it was unhook the vacuum advance Went to the car show the other night on my way back coming up the hill I could hear a little bit of ping but not as much is it was
You need to see how much mechanical advance is built into the unit. You'll need a dial back timing light and a tach. Basically set the initial timing to 16*, run the rpms up and watch the timing light for when the timing stops advancing, note how much advance is showing when the timing stops and at what rpm it stops. Subtract 16 from the number you get from the amount of advance you got in the previous step.
If you can accomplish this, please post the results.
I read the instructions and they do not tell how much advance you get.
https://www.topstreetperformance.com...stributor.html
