hv oil pump or change to standard?
Old Feb 10, 2012 | 02:26 PM
Ausraven's Avatar
Just a quick question for all you oil people. I have recently rebuilt my 455 and I left it pretty well stock except 30 thou over pistons and a hv oil pump. I also put in hydraulic lifters too. After I warm it up I can hear the faintest tappet noise at around 2000rpm. I am wondering if the hv oil pump is the culprit, maybe starving the top end a little? Also I have speco gauges and I am getting a reading of around 70 for oil pressure when cruising down the highway? I know these gauges can be out but from what I read on other threads that is too high.
Old Feb 10, 2012 | 02:48 PM
WoofWagon's Avatar
Unless you are building a ***** out race engine, stick with the stock pump.
Old Feb 10, 2012 | 04:44 PM
Did you relace all the rockers and stands when you rebuilt it? Are they all tight? What oil are you running?
Old Feb 10, 2012 | 05:06 PM
cutlassefi's Avatar
Stock cam? What's the oil pressure at idle hot? Cruising hot?
Oldsragger
Jul 4, 2015 02:42 AM
dre
Drivetrain/Differentials
Aug 31, 2011 11:04 AM
86pontiac
Feb 17, 2010 11:24 AM
