How to set points (455)
Old Jul 28, 2014 | 01:41 PM
CrazedCountryRebel's Avatar
TalksToToads
So I was wondering if anyone had any good tips on an easy way to set the points on my 68 Delta 88? I looked at the shop manual but it says to use all these fancy GM tools that you probably can't get any more.
Old Jul 28, 2014 | 03:23 PM
RandyS's Avatar
Yes, very simple. The only tools you need are a 'Dwell Meter' and an allen wrench. Set the dwell to 30 degrees.
Old Jul 28, 2014 | 03:33 PM
I'll add you also need a timing light as when you set your dwell it will change your timing. This tool will help with the points:
Old Jul 28, 2014 | 04:24 PM
redoldsman's Avatar
Proud Viet Nam Veteran
If you don't have a delimiter set them at 16 thousandth.
Old Jul 28, 2014 | 05:32 PM
Yup. Nothing easier. Connect dwell meter, turn Allen key (preferably springy purpose-built one, but a rigid L-shaped one will do) until needle points to 30°, connect timing light, re-set timing if necessary.
Old Jul 28, 2014 | 06:37 PM
Octania's Avatar
It's even easier than that.
Old Racer's Trick
Turn adjuster in [CW] until engine falters
turn back out [CCW] exactly 1/2 turn.
Voila' 30 degree dwell plus or minus 2 degrees, per spec.
I verified this once long ago on my '68
Old Jul 28, 2014 | 07:39 PM
TalksToToads
Cool, Thanks guys! I think I will try Octania's trick first.
Old Jul 28, 2014 | 09:34 PM
nsnarsk65cutlass's Avatar
Another old trick is to set the gap with a match book it will get you in the ball park.
Old Jul 28, 2014 | 09:42 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Be sure to not touch the contacts with your meat hooks. If you do clean them with a lint, grease free towel with contact cleaner(or brake cleaner). Clean the feeler gauge as well before (if) you use them. If not the oil will cause pitting in a short period of time. Also be sure the dist cam is clean then lightly regrease bumper with a dab of grease in the favor of dist rotation
dynamic88builder
Dec 30, 2019 07:24 PM
malatu
May 5, 2008 09:24 AM
Specman
Mar 16, 2007 05:59 AM
For Sale
Mar 15, 2007 12:25 PM
