horse power 73 455 toro engine
Old Sep 8, 2009 | 07:20 AM
olds4life's Avatar
hey olds nations!!!!!!!!!!!!! whats the horsepower in a 73 455 toro engine. thanks
Old Sep 8, 2009 | 07:29 AM
Alot!
FWIW, I've heard the factory HP and torque ratings aren't very accurate. If you are searching for a 455 to replace an engine in your Cutlass or to rebuild then I would buy it.
Old Sep 8, 2009 | 07:41 AM
citcapp's Avatar
Low compression engine, around 275hp, smog J heads not the best.
Old Sep 8, 2009 | 08:57 AM
Heads can easily be replaced. Plus, if you are rebuilding it anyways you can put some higher compression pistons in it.
69CutlassAlex
Jun 9, 2012 08:59 AM
Texas Jim
Jan 11, 2011 09:41 AM
808olds
Sep 20, 2010 05:10 AM
diablo76delta88
Feb 17, 2009 10:57 AM
topjimmy19
Oct 28, 2007 06:44 PM
