heres a really good reason you should check to make sure your header bolts are tight
Old September 19th, 2010 | 10:46 AM
chris83's Avatar
I took my car to the mechanic to have new header gaskets put on. When i got my car back it sounded like it had a spun bearing. So i got upset with the mechanic and had tons of witnesses saying he was out hot rodding my car. So i said some pretty nasty stuff and brought my car home and started tearing it down. First taking valve covers off, because mechanic said he thought oil pump went out. So i pulled covers and it was oiling just fine. A couple different mechanics looked at it and told me was rear main crank bearing or cam bearing. Then i thought noise was coming from tranny. So i jacked car up and seen that the flex plate does look a lil bent and started to procede to take tranny out yesterday. Then my buddy jerry asked when the noise started and i told him right after header gaskets where replaced. He said well lets check header bolts to see if tight, and they where all loose. Other mechanic must have put in just finger tight, and forgot to tighten. So he tightened them and wow no noise! Super cheap fix, so make sure your header bolts are tight. All this almost cost me pulling my motor out and being out money. When all along it was loose header bolts. lol So just some advice for you guys to save some money. Im glad i didnt pull motor and sell it, cause i was fed up. So good luck to you guys.
Old September 19th, 2010 | 11:22 AM
Bluevista's Avatar
Registered
I don't have headers?
I am out of breath after reading your post though.
Glad you found out what was wrong, it would of never occured to me that the last thing done to the car before it messed up could be the problem?
Thanks for the heads up.
Next time do yourself a big favor and call your buddy Jerry first.
Old September 19th, 2010 | 11:25 AM
Lady72nRob71's Avatar
The little simple things can cause a big headache. Glad you checked them Too bad you had to finish the mechanic's job though.......
Old September 19th, 2010 | 11:31 AM
Oldsguy's Avatar
Past Administrator
Well, eventually you would have gotten to the headers anyway before the engine could have come out.
Old September 19th, 2010 | 12:19 PM
Run to Rund's Avatar
Good story pointing out there are seldom coincidences. That post also is a record on this forum for the longest single sentence, with zero capitalization or punctuation lol. Kidding aside, glad you posted your experience.
Old September 19th, 2010 | 02:20 PM
69Rman's Avatar
Same thoughts here. I'll need to quit smoking just to keep up with posts like this one.
...it would of never occured to me that the last thing done to the car before it messed up could be the problem?
Blue, Your approach to these types of posts always makes me laugh.
Sarcasm at it's best!
Duane
Old September 19th, 2010 | 02:25 PM
64Olds98's Avatar
It wasn't until I read this that I realized I hadn't breathed the entire time I was reading. Then I looked and there is no punctuation, so I guess I never took the time to stop. I never realized that happens when you're reading in your head
Old September 19th, 2010 | 02:29 PM
64Olds98's Avatar
Also, it made me think of this video...
Old September 19th, 2010 | 06:35 PM
TripDeuces's Avatar
I'll take a punctuation marks for $100 Alex
Old September 19th, 2010 | 07:48 PM
chris83's Avatar
hey im a truck driver we dont use no punctuation ha ha ha ha ha i was just writing and writing and writing ha ha ha
Old September 20th, 2010 | 07:38 AM
I was thinking about getting a set of locking header bolts for my 71 98.
http://www.summitracing.com/parts/STG-8956/
Good to hear that you figured out the problem.
Old September 20th, 2010 | 09:15 AM
scubastever's Avatar
this is not my car lol
i would never ever go back to a shop that cant even perform a simple task as this.
black listed & boycotted, for life!
nolabigdawg
October 25th, 2014 12:50 PM
costpenn
Drivetrain/Differentials
September 16th, 2011 12:08 PM
BIGJERR
September 26th, 2009 10:27 AM
jeffreyalman
August 28th, 2009 07:14 PM
