Help..help....hei
Old Jun 8, 2013 | 08:40 AM
scooter123's Avatar
Help..help....hei
Sorry for starting a new post guys but I have to get this fix asap...going to a show today...I hope!!
So I got the car to start this morning but the new hei is making a clicking sound....and I got one hell of a shock
so the coil instructions said to ground using the coil screw..as you will see in my first pic
The plug from my new distributor has three wires that is 1 yellow....1 red....1 black that hooks to nothing.....is there suppose to be a ground wire of some sort going to that black wire on the distributor plug???
Old Jun 8, 2013 | 08:56 AM
s i 442's Avatar
Oldsmobile enthusiast
That plug will plug in only one way most likely the red wire towards the firewall.
If there is no ground wire don't worry about it.
Old Jun 8, 2013 | 09:00 AM
scooter123's Avatar
As I said...im getting a major spark leak...and clicking noise.....all videos Ive watched online shows a ground strap under the coil.....and the spade connects to the black on the distributor plug
Old Jun 8, 2013 | 09:02 AM
Octania's Avatar
the coil has to ground somewhere
It's been a while but I think you are missing a "wire" that is a formed pc of conductor from the center terminal to where the coil's black wire is secured at a mtg screw.
Old Jun 8, 2013 | 09:33 AM
scooter123's Avatar
Just went back to napa and got the right ground strap
Old Jun 8, 2013 | 10:59 AM
scooter123's Avatar
All is good with the new distributor/hei...thanks for the help guys!!!1
Old Jun 8, 2013 | 02:04 PM
Well how does it run? What did you set your timing to?
joepenoso
Jun 4, 2014 01:56 PM
Mark71
Nov 13, 2011 11:00 AM
oldscruiser
Feb 15, 2011 12:44 AM
chopper charlie
Tech Editor's Desk
Aug 3, 2010 06:04 PM
dallasite21
Jan 30, 2010 04:57 PM
