help with deep oil pan and dipstick reading
Old Aug 31, 2019 | 05:13 PM
yellowrocket's Avatar
Hi, I am looking for some info from anybody using a 7.5 quart oil pan as to where on a stock 455 stick the level reads . I am not sure if I have 2 or three quarts in the engine so I added 4 and it is just showing on the stick .
Old Aug 31, 2019 | 06:53 PM
You can do an oil change and then mark your dipstick for your desired level.
Old Aug 31, 2019 | 07:57 PM
The full level won’t change between pan depth. If it was full with the stock pan the full level will take more oil to reach the same level with the deeper pan.
Most people run run a deeper pan below full to keep the oil further from the rotating parts. Less windage, more power. Look at it like this, a 7 quart pan with the level reading a quart low still has more oil in the pan the a stock pan reading full.
Old Sep 1, 2019 | 04:21 AM
Matt69, I understand about the amount of oil in the pan, just was looking to see if I will have to make an adjustment to the tube height to get a better reading on the dipstick, which as of right now the level was just barely showing on the stick.
Old Sep 1, 2019 | 05:10 AM
It depends on how much oil your going to put in the engine. The stock stick was designed for a specific pan and filter filled with a specific amount of oil, you changed that.
Old Sep 1, 2019 | 05:14 AM
cutlassefi's Avatar
I’ve never seen a 7.5qt pan for an Olds. What make is it?
Old Sep 1, 2019 | 05:20 AM
HI, cutlass , It is mondello kit . I think it is 7 quart pan and with filter makes the 7.5 . Been while since I talked to you , but finally got the engine done and in the car .
Old Sep 1, 2019 | 06:14 AM
cutlassefi's Avatar
Ok but FYI you always go by the pan volume alone as a reference.
On every aftermarket 7qt pan I’ve ever seen/used when the stick reads 1 qt low it’s normally full.
Old Sep 1, 2019 | 06:42 AM
Think I figured it out . It would seem that the stick was riding on top of the baffle in the pan . I massaged the stick with a little more of a curve to the center of the engine and now it shows level at add line ,which is where like Cutlass said , makes sense as to full line.
george landis
Aug 16, 2019 03:26 PM
71Cruiser
May 30, 2019 07:14 AM
yellowrocket
May 28, 2019 03:13 PM
Jolly Green
Feb 14, 2012 08:37 PM
815Cutlass1972
May 13, 2010 11:43 AM
