help choosing carb. and distributor
Ok, im clueless what to look for in these areas for parts for my application. I am looking for some recommendations for carb. and distributor as the title indicates and maybe some general info too.
Going to use on the street and may see the track from time to time, mostly street though, run premium gas
Intake - Edel. 2151
Cam - Erson TQ50
Heads - Stock E
Pistons - IC886KTD
Block bore - .030
Crank - Stock
Trans. - unknown manual. m22?
Rearend - 3.73
Intake - Edel. 2151
Cam - Erson TQ50
Heads - Stock E
Pistons - IC886KTD
Block bore - .030
Crank - Stock
Rearend - 3.73
Well you want a carb that your engine will use all if not most of the cfms there's an equation I can't remember but it also depends on build and most people use hei I like mallory and msd but they exxxxxpendive but again depends on build
You can use a Rochester, or a square bore carb in the 750 cfm range. I don't know if you prefer a mechanical secondary or a vacuum. It also depends on how your going to drive it. For the distributor an Hei will probably work fine.
Any pros or cons regarding mechanical vs vacuum?
Look on Ebay for the 750 Holley there are tons of used ones and Holley are pretty easy to rebuild. You can buy new HEI's for pretty cheap from Summit. With a 4 speed and a nice gear like you have I'd use a double pumper as long as gas milage is secondary to performance.
Did you happen to mention what year car and engine you have and what you are starting with, or did I just miss it? Does it presently have an intake, carb and distributor? Most people on this site and the Pontiac site, for that matter will recommend a Quadrajet and a stock manifold, especially if it is mainly for the street. If you already have those items, it takes a lot less money to make them work.
Intake - Edel. 2151
Cam - Erson TQ50
Heads - Stock E
Pistons - IC886KTD
Block bore - .030
Crank - Stock
Rearend - 3.73
Intake - Edel. 2151
Cam - Erson TQ50
Heads - Stock E
Pistons - IC886KTD
Block bore - .030
Crank - Stock
Rearend - 3.73
first post. The year of the car is a 70 442, block is a 73, 455 carb and distributor were not with it
