help choosing carb. and distributor
Old Jan 22, 2014 | 07:02 PM
foo's Avatar
foo
Ok, im clueless what to look for in these areas for parts for my application. I am looking for some recommendations for carb. and distributor as the title indicates and maybe some general info too.
Going to use on the street and may see the track from time to time, mostly street though, run premium gas
Intake - Edel. 2151
Cam - Erson TQ50
Heads - Stock E
Pistons - IC886KTD
Block bore - .030
Crank - Stock
Trans. - unknown manual. m22?
Rearend - 3.73
Old Jan 22, 2014 | 07:28 PM
billmerbach's Avatar
major noob
Well you want a carb that your engine will use all if not most of the cfms there's an equation I can't remember but it also depends on build and most people use hei I like mallory and msd but they exxxxxpendive but again depends on build
Old Jan 22, 2014 | 07:29 PM
foo's Avatar
foo
I forgot to mention im not looking to break the bank either
Old Jan 22, 2014 | 07:34 PM
major noob
That's what I figured lol well with the distributor more than likely hei will do u good and I'm not a carb person but I think match it with the intake
Old Jan 22, 2014 | 07:43 PM
coppercutlass's Avatar
Chevy budget Olds powered
A 750 holley should be fine.
You can use a Rochester, or a square bore carb in the 750 cfm range. I don't know if you prefer a mechanical secondary or a vacuum. It also depends on how your going to drive it. For the distributor an Hei will probably work fine.
Old Jan 23, 2014 | 01:14 AM
foo's Avatar
foo
Any pros or cons regarding mechanical vs vacuum?
Old Jan 23, 2014 | 04:28 AM
Mechanical double pumpers shoot a lot of initial fuel since you have dual accelerator pumps. The vac. Secondaries work off vac. So it goes by what the engine demands.
Old Jan 23, 2014 | 05:05 AM
cutlassefi's Avatar
I'd do either a Holley Street Avenger 770 or QF 780.
Old Jan 23, 2014 | 05:43 AM
Since you have a manual transmission you might want to look into a mechanical secondary carbs if your looking for performance.
Old Jan 23, 2014 | 06:19 AM
cutlassefi's Avatar
X2. If you go with the manual, I'd do a QF 850 Double pump.
Old Jan 23, 2014 | 02:05 PM
foo's Avatar
foo
sounds good, Im in my research phase atm since its so cold out. I appreciate the replies
Old Jan 23, 2014 | 02:10 PM
455man's Avatar
The problem with a vacuum secondary is when you let off the gas and shift gears at WOT the vacuum comes back and can close the secondaries. With the mechanical you dont have that problem.
Old Jan 24, 2014 | 02:31 PM
jag1886's Avatar
Look on Ebay for the 750 Holley there are tons of used ones and Holley are pretty easy to rebuild. You can buy new HEI's for pretty cheap from Summit. With a 4 speed and a nice gear like you have I'd use a double pumper as long as gas milage is secondary to performance.
Old Jan 24, 2014 | 02:32 PM
jag1886's Avatar
Not to be a smart *** but you must shift gears awfully slow.
Old Jan 24, 2014 | 02:50 PM
brown7373's Avatar
Did you happen to mention what year car and engine you have and what you are starting with, or did I just miss it? Does it presently have an intake, carb and distributor? Most people on this site and the Pontiac site, for that matter will recommend a Quadrajet and a stock manifold, especially if it is mainly for the street. If you already have those items, it takes a lot less money to make them work.
Old Jan 24, 2014 | 03:04 PM
foo's Avatar
foo
Intake - Edel. 2151
Cam - Erson TQ50
Heads - Stock E
Pistons - IC886KTD
Block bore - .030
Crank - Stock
Rearend - 3.73
first post. The year of the car is a 70 442, block is a 73, 455 carb and distributor were not with it
DYSKIE
Jan 24, 2015 07:14 AM
young olds
Dec 23, 2014 09:59 PM
Al2011
Aug 24, 2011 06:58 PM
Al2011
Aug 16, 2011 08:03 AM
1FSTLS1
Dec 20, 2008 05:45 AM
