help 455 low compression pistons swap?
Old Mar 26, 2010 | 06:26 AM
dgreen's Avatar
hello again i have a 72 455 with ga heads small valves the cylinders are in great shape about .001 over stock bore size i was gonna hone it and put new rings on but now im thinking i could swap the pistons and get a little more compression can anyone tell me if this is doable and what pistons to get and what the compression would be thanks!
Old Mar 26, 2010 | 09:38 AM
507OLDS's Avatar
I am in Erie(actually Girard).Where are you? You could install another set of stock pistons,from a 68-70 455.They have a much smaller dish.The 2bbl engines had a slightly larger dish,but still smaller than the dish in your 72 pistons.I have stuff like that here,if you decide to do that.
Old Mar 26, 2010 | 10:19 AM
dgreen's Avatar
thats good news im in cambridge springs let me know what ya got i wasnt sure how much the compression would be with the 1970 style high compression pistons with the 72 ga heads thanks
Jaybird
Apr 8, 2012 11:15 PM
Ficks
Mar 25, 2011 06:43 PM
Jaybird
Feb 10, 2011 05:48 PM
Jaybird
Dec 1, 2010 06:59 PM
