330 Pistons High/Low compression
Old Mar 25, 2011 | 05:25 PM
Ficks's Avatar
I am rebuilding my 330 Olds engine. It came out with a 4brl carb and high compression pistons. I am putting in a slightly higher cam than stock so the question is: Do I replace with high compression pistons and always use high octane fuel or put in low compression pistons and use regular? Will it make that much difference? It will be just a very low yearly mileage car.
Old Mar 25, 2011 | 06:35 PM
cutlassefi's Avatar
Cam and compression go together, what cam are you using?
Old Mar 25, 2011 | 06:43 PM
Oldsmaniac's Avatar
Put the HC's in you will be disappointed if you dont.
Beeks69
Jun 3, 2015 07:20 AM
MudEye
Jun 2, 2015 10:45 AM
Jaybird
Apr 8, 2012 11:15 PM
dgreen
Mar 26, 2010 10:19 AM
