HEI Distributer
Same distributor. Sounds like the teeth aren't meshing. May I suggest you get it to start seating (distributor shaft starts to mesh with the cam gear and won't turn) and GENTLY tap on the distributor shaft with a rubber or rawhide mallet.
C.J.
C.J.
Sounds like the oil pump shaft is not lined up. You may have to bump the engine or turn it with a socket on the front damper . Just turn it a little until the shaft lines up. Make sure you have the rotor line up with #1 plug wire when it seats. I don't think beating on it is going to help.
Gene
Gene
Gene,
Good thinking! But I wasn't suggesting "beating on it". I had problems seating mine and a little "friendly persuasion" helped.
And remember that the distributor shaft rotates slightly as it seats completely.
C.J.
C.J.
joepenoso
Jun 4, 2014 01:56 PM
