heeeeeelp..............
Old Mar 21, 2011 | 09:31 AM
antweave's Avatar
I am restoring and rebuilding my 455 in my 71 442 clone the engine will be bone stock only .30 over. I need a radiator can a 2 core radiator keep this big block cool.
Old Mar 21, 2011 | 09:33 AM
citcapp's Avatar
Nope 3-core at minimum and most guys recommend a 4-core
Old Mar 21, 2011 | 10:52 AM
455man's Avatar
My 3 core ran hot on 100 degree days. I say hot but it ran 210 with a 160 thermostat in it. I'd go 4 core.
Old Mar 21, 2011 | 11:22 AM
panos's Avatar
I have a mild build 461 (0,30 over) and use a 2 core griffin alum.radiator with 1.25" cores and dont have any problem at all never went over 175
Old Mar 21, 2011 | 11:32 AM
panos's Avatar
This one http://www.summitracing.com/parts/GRI-1-55272-X/
Old Mar 21, 2011 | 12:20 PM
D Appeldorn's Avatar
mmm i drive a 2 core from the original 350 in my 69' 88 with now a 455 in it.
no problems, i put the right pressure cap on it and a new fanclutch.
even stay'd under 200F at 100+ m/h on the autobahn
Just trie, and buy it when needed
Old Mar 21, 2011 | 12:31 PM
before i making a mistake and say it is a 2row a shall look tomorow
I thought it is, but i run a original HD cooling fan on my 69' 88 i forget to mention.
Old Mar 22, 2011 | 04:20 AM
Texas Jim's Avatar
Texas Jim
I have the original '71 Olds 98 radiator cooling the 455 that it came from the factory w/ using a 160 degree thermostat. The engine stays cool and even last summer, the temp never got to 180, and I'm in central Texas. That stock radiator sure doesn't look like any three or four core.
Old Mar 22, 2011 | 11:56 AM
depending how i use mine, 176F? (80degree celcius) is my normal temp.
As i refer, it went just below 212F (100degree celcius) after a goose chase on the german auto bahn.
After longer periode of 100m/h and id did'nt get hotter than that.
your tempsender gives hot at 248F !!! take or less 2F (1969 unit)
if it blows, the fault is the radiatorcap or the mixture should be 14 til 17psi and a 50/50 mixture (1969)
the normal temp range should be in 180/ 190 F as with normal enviroment temps the
The radiator will not do much with temps below 180/ 190, is it more than that the thermostat opens and cools the engine faster.
i'd have a 160 thermostat in it, and it take's longer to get the engine on normal working temp after cold starts.
This is not a problem in summer or hot weather.
So just trie, or buy a new radiator.
I do have it on my wish list, a nice alu radiator.
reason why, it is clean! and new. no rust or plain water use residu.
Old Apr 2, 2011 | 06:08 PM
philnjean's Avatar
I'm running the stock two row radiator on my 461 with a flex blade. Doesn't overheat at all..
76_cutty
Jun 2, 2010 04:04 PM
