Heater control valve
Searched past threads but did not find any that say what to use on the threads of the heater control valve that screws into the rear pass side of the aluminum intake,(if any should be used). The intake is a repop W-30 aluminum and the valve seems to be another type metal that a magnet will stick to. Any suggestions? Thanks
Thanks Eric. I have that book and found it in there. I did not know that was covered till you mentioned it. Going to have to look at that book thoroughly as I may be missing more stuff. Thanks again!
I used Permatex thread sealant, but I forget which one (they make several that will work). Same stuff I used on the water pump bolts. http://www.permatex.com/products-2/p...hread-sealants
jensenracing77
March 19th, 2014 04:08 PM
