Heater control valve
Old Jul 15, 2014 | 01:08 PM
Gary M's Avatar
Searched past threads but did not find any that say what to use on the threads of the heater control valve that screws into the rear pass side of the aluminum intake,(if any should be used). The intake is a repop W-30 aluminum and the valve seems to be another type metal that a magnet will stick to. Any suggestions? Thanks
Old Jul 15, 2014 | 01:24 PM
I used teflon tape on mine. Non-hardening thread sealer is fine, too.
Old Jul 15, 2014 | 01:27 PM
70cutty's Avatar
Beer Connoisseur
X2 teflon tape
Old Jul 15, 2014 | 01:41 PM
Gary M's Avatar
Thanks. I think I'll try the Teflon. Nervous about the threads since the old one was hard to get out. Checked the threads though and they seem fine. Thanks again!
Old Jul 15, 2014 | 03:41 PM
Note that an illustration in the Assembly Manual tells you the exact angle you are supposed to clock the valve at.
Old Jul 15, 2014 | 04:40 PM
Gary M's Avatar
Thanks Eric. I have that book and found it in there. I did not know that was covered till you mentioned it. Going to have to look at that book thoroughly as I may be missing more stuff. Thanks again!
Old Jul 16, 2014 | 07:30 AM
68442Convertible's Avatar
I used Permatex thread sealant, but I forget which one (they make several that will work). Same stuff I used on the water pump bolts. http://www.permatex.com/products-2/p...hread-sealants
jensenracing77
Mar 19, 2014 04:08 PM
zodiacblueS
Apr 7, 2012 02:38 PM
Mister
May 13, 2011 03:53 PM
blue72regency
Dec 12, 2007 01:12 PM
bjtstarfire
Dec 15, 2006 10:14 AM
