Headers for b-body
Old Jan 3, 2015 | 08:03 PM
Oldsragger's Avatar
Headers for b-body
Does any know about what headers I can use with a bbo in a b-body car? I have only this on pics, but don't know what they are from ,
(I have not tried this yet btw) does headers have a product nr on the headers somewhere I can find?
sorry bad pic
Old Jan 4, 2015 | 08:54 AM
Lars's Avatar
from Jchicago
Hedman 58150 Headers are a perfect fit.
A 200c crossmember is the same as a th350.
93-96 9c1 Caprice dual hump crossmembers will bolt right in, but 700R4's have a different trans mounting scheme. You will have to trim the front hump off a Caprice crossmember, and possibly modify the ears where they mount to the frame if you want to run a th350. It may be more trouble than modifying a stock th350 crossmember. If you want to run stock exhaust manifolds, you will will most likely have the easiest time blocking off the back passenger bung by welding it shut, and running the exhaust down from where the crossover pipe was.
http://www.oldspower.com/vb/showthre...t=delta+header
Old Jan 4, 2015 | 01:29 PM
Oldsragger's Avatar
Thanks for tip, crossmember Will not be a problem, i Just think my headers Will fit bad maybe in the engineroom, But i Will check out the headman 58150 headers if i need to modify my headers much if so.
Old Apr 9, 2015 | 01:58 PM
Oldsragger's Avatar
Hi again, do you know if i need a ministarter for the hedman 58150? Or will them crash into the big starter.. I have not order the headers yet.
Old Apr 9, 2015 | 02:28 PM
Redog's Avatar
Unknown, but I can let you know in a few weeks when I do my 330 in my Delta.
I'll be running a SBO though
Old Apr 10, 2015 | 03:16 PM
Oldsragger's Avatar
OK thanks, i guess i have the engine still out that time. Maybe i will just buy the headman for sure anyway and sell the old ones, but i dont know what they are from
Wyze
Mar 18, 2012 01:59 PM
rustyold66
Aug 14, 2008 09:01 AM
J-(Chicago)
Mar 6, 2008 04:15 PM
dar83501
Nov 20, 2007 11:45 PM
dar83501
Oct 14, 2007 12:35 PM
