Headers
Old Sep 19, 2013 | 11:02 AM
ctreutel's Avatar
Headers
Hi All;
My engine rebuild project continues! I have a 1969 442 with a 455. Completely rebuilt the engine and now about to install. My question is on exhaust headers. I'd like to get new headers because the ones on the car now, do not fit properly [actually rub on the steering column]. Does anyone have suggestions on where I can buy headers that will fit?
Old Sep 19, 2013 | 11:13 AM
chadman's Avatar
Depends on how much you want to spend. ARH stainless headers are the absolute best on the market for an Olds. They are also however the most expensive. For a cheaper header that fits pretty good the Hookers are hard to beat.
Old Sep 19, 2013 | 11:34 AM
ctreutel's Avatar
I am WAY over budget...so I'd like to save some bucks if I could. I see Summit has Hooker headers [part number 3902HKR] for $245. This a good deal? Any other suggestions? anyone have experience with this particular Hooker model?
Old Sep 19, 2013 | 11:48 AM
I've heard alot of negative reports on headers for A bodies. I would either keep the headers you have now, or spend the money to get a set that fits right. I've heard Doug's headers are top notch, they aren't cheap though:
http://dougsheaders.com/
Old Sep 19, 2013 | 05:14 PM
ziff396's Avatar
If money is tight, and your old headers are in good condition, just mark where they are rubbing and put a small ding there to clear the steering shaft. Common place with headers. Re finish them and you are good to go without spending a lot of money. A lot of headers, being new, cheap, or expensive will need a little massaging to fit right.
Old Sep 19, 2013 | 05:28 PM
I would go this route until you have enough money to get a good coated set.
Old Sep 20, 2013 | 12:25 PM
That is a bummer that there are so few options that fit well for A bodies. The Heddman headers I got for my 71 98 fit perfectly.
Old Sep 20, 2013 | 12:33 PM
pogo69's Avatar
morgan
i still have blackjack headers on my car 25 years+ no leaks.... i'm not sure if they still make them
Old Sep 20, 2013 | 01:13 PM
The best-fitting Olds headers I've ever used were made by Kenne-Bell back in the 1980s. Unfortunately Kenne-Bell stopped making Olds parts decades ago.
Old Sep 20, 2013 | 01:28 PM
ctreutel's Avatar
Thanks much for the input guys...much appreciated
Old Sep 20, 2013 | 02:41 PM
BTW, people have had good luck with Hookers, I had to lightly massage my Hedmans here and there.
Old Sep 20, 2013 | 03:34 PM
drjr56's Avatar
I have a 69 442 power steering,power brakes,had ac but was removed,still has the box on the firewall though,an 8 qt pan ,and my headers are hedman and they fit fine,no leaks either..oh yeah car has a 455 also and a 400 turbo trans.
Old Oct 14, 2013 | 08:21 AM
real57vetteguy's Avatar
I know this is an old thread but keep in mind there is a HUGE issue with the Hooker 7902 series and maybe with others not even being close to a proper fit regarding head port to header port!
Wyze
Mar 18, 2012 01:59 PM
martine
Feb 13, 2007 11:57 AM
JoshF85
Jan 24, 2006 10:20 AM
javi58
Apr 20, 2005 07:53 AM
<72>
Nov 11, 2004 09:09 PM
