Camshaft bearings
Old Oct 12, 2013 | 09:07 AM
jankyrre's Avatar
Camshaft bearings
What tool do you guys use to install new camshaft bearings?
The new ones have very sharp edges so I guess they have to be installed in a gentle way.
I know there is a spec.tool for this,but it must be possible with a selfmade tool.
Old Oct 12, 2013 | 09:21 AM
No, it isn't. Get the correct tool or risk screwing up your cam bearings.
Old Oct 12, 2013 | 01:12 PM
jankyrre's Avatar
Ok.
Does this one work?One tool can do all bearings.
Can't find it in Norway so I have to buy it in US.
Anybody know where to purchase them?
How do you remove the aft bearing.There is a ridge behind it so it have to be pulled out towards the front.
Old Oct 12, 2013 | 01:21 PM
Google "cam bearing tool". You'll find many, including relatively inexpensive ones from Summit and Jegs. I bought mine used for even less. Knock out the freeze plug behind the rear cam bearing for access.
Old Oct 12, 2013 | 01:24 PM
The one I have looks like this. The collets expand to fit the bearings tightly. The white plastic cone is for centering the tool. I believe mine is Lisle brand.
Old Oct 12, 2013 | 01:27 PM
Here's a link to the Lisle instructions:
http://www.lislecorp.com/uploads/ins...6DD9726DB5.pdf
Old Oct 14, 2013 | 02:07 PM
jankyrre's Avatar
Thank you.
I better order one.They are about $140 on e-bay.
oldzy
Drivetrain/Differentials
Sep 14, 2010 05:40 AM
olds1968
Apr 18, 2008 08:39 AM
Andrew240
Dec 22, 2007 01:54 PM
olds350
Dec 21, 2006 05:11 PM
