Headers for 394
AFAIK, they have never been made commercially. Custom proposition only. You might check header gaskets for more popular engines and see if something is close, then if the headers will fit the chassis, as is or modified. Stuff like small block Chevy and big block Mopar might come somewhere close at the flanges, be possible to modify.
There are commercial headers for the first gen Olds V8 in a street rod, but not in a stock passenger car body. You might want to try these folks for a custom set. At least you should be able to buy the exhaust flanges from them:
http://www.lakeheaders.com/oldsmobile_headers.html
There's also a very informative thread on the first gen V8 over at H.A.M.B.:
http://www.jalopyjournal.com/forum/s...d.php?t=149650
More info on exhaust flanges.
Headers by Ed sells flanges with starter tubes:
http://www.headersbyed.com/__oldsmobile.htm
Victory Header Flanges has them also:
http://www.victoryheaderflanges.com/...ldsmobile.html
wr1970
March 29th, 2015 05:36 AM
eddieunderground
August 12th, 2010 05:44 AM
