Headers❓
Old Nov 3, 2019 | 07:48 PM
Josh Robb's Avatar
Headers❓
Hi, im looking to buy a set of headers for my 1972 olds 442 pretty much stock 455 with after market eddelbrok intake & holley carb 670 can anyone recommend a good set that should fit with no issues & that can clear starter❓ Thanks in advance 👍
Old Nov 3, 2019 | 08:23 PM
Run to Rund's Avatar
American Racing Headers are stainless steel and have a top reputation for quality and fit.
Old Nov 3, 2019 | 08:57 PM
coppercutlass's Avatar
Chevy budget Olds powered
All headers clear the starter for the most part as an observation ( I have only had crappy offshore headers but I have had no issues) but most headers sit tight on the stock size starter . But with headers I highly recommend 2 things. a quick disconnect for the starter and a mini starter. You will not be able to put in a stock stater with headers in place you will have to hang the header , install the starter then bolt the headers up. Even with my mini starter its the same thing but its lighter. Just FWIW.
Old Nov 4, 2019 | 02:40 AM
dragline's Avatar
My next set will be the Thornton headers. I love the design.
https://www.ebay.com/itm/Oldsmobile-...IAAOSwv6Fbukop
Old Nov 4, 2019 | 03:51 AM
Oldsmaniac's Avatar
Installed Flowtech's I believe in a friends 72 455 vert, drivers side was hitting the frame had to bash a couple of tubes in, would NOT recommend, I like Hooker headers, and yes they will fit a convertible.
Old Nov 4, 2019 | 05:03 AM
bccan's Avatar
I like Hookers, as do Robert Kraft, Hugh Grant, Danny Bonaducci......
Old Nov 4, 2019 | 04:45 PM
OLE442's Avatar
Just ordered a set of these for my 72 442! They’re supposed to arrive this week from Thornton’s! Trying to sell off my NIB Ebay special stainless in the classifieds right now if any one is interested!
OLE442
Old Nov 4, 2019 | 07:50 PM
BackInTheGame's Avatar
I used Hookers on my '68 4-4-2. It is a 4 speed car, and even after installing new engine mounts I had to massage the under side of the cylinder 7 tube so that it would not rub on the bell crank. Other than that, no fitment issues, keeping the starter info above in mind.
Old Nov 5, 2019 | 07:52 AM
zekecut70's Avatar
https://hudsonvalley.craigslist.org/pts/7010533585.html
Give me a call
Old Nov 5, 2019 | 02:46 PM
Rallye469's Avatar
I wonder how those Thornton’s flow?
(vs. long tube headers)
-pete
Old Nov 5, 2019 | 02:50 PM
Thornton headers are like glorified manifolds. None of the true advantages of headers are really incorporated to the design. They do however look better than manifolds.
Jan 1, 2016 05:55 AM
Grant1424
Aug 21, 2015 05:11 AM
70cutty
Feb 11, 2014 07:00 AM
timothypaul
Sep 20, 2012 07:58 AM
gumbyssfakee
Jan 6, 2009 02:11 PM
