455 help please!
455 help please!
I just got a 72 toronado fornext to nothing, trying to get it running. it hasnt run since 2009. 455 is locked up. been soaking the cylinders with pb blaster for couple days and trying to crank it from the front crankshaft nut with a breaker bar and in between bumping the starter. no go yet. when i took plugs out 2 cylinders had coolsnt in the wells. any suggestions?
I agree with Randy sometimes you get lucky with them ,but you could be doing more harm than good forcing it .The car may have been put away due to blown head gaskets and who knows what else.Pulling the motor and getting a good assessment of it's condition is a good idea. what are your plans for the car?
Once you get the heads off, get a piece of solid wood and smack the piston tops at the top and bottom of the piston bore. The idea is to get the piston to rock, that will allow penetrating oil around the rings. If that doesn’t work, a air hammer with a chisel bit is the next move. Don’t worry about trying to save the pistons, and this point the corrosion to the piston and bore will be too bad to use. The pistons will be junk, and the block will need bored
Not sure how an air hammer would hurt anything at this point, as stated piston are junk anyway and block may be borderline. Have used a torch to cut out center of piston before getting piston to move enough to disassemble.
How do you know? You have a crystal ball? Who said the block is junk? Nobody has seen engine except the op.
And I say your method should be as a last resort. I have done these type of removals since I was a kid and never done it your way. My dad owned a salvage yard back in the day motors were torn apart. They wouldn't accept them whole or short block at foundries to much weight and to big to go through the charging floor door in the furnace. Ask me how I know.
This is just a thought and its way out there. but maybe buy 8 cans of freeze off and spray them into the cylinders 1 can per cylinder. It might be enough for things to shrink and get the PB blaster into the stuck areas . Again just an out of the box idea.
Copper where do you buy that stuff at? Never heard of freeze off. That might work that is a ideal out of the box .😁
