Head bolt/Main bolt prep?
Most people mention chasing the threads of the head bolt holes when prepping the block but I am in the process of cleaning everything on my disassembled 455 and it occurred to me that I have never heard anyone mention head or main bolt prep. I have cleaned the main bolts with a manually operated wire brush so they are clean but after they are dried off the surface is a bit rough. Is there a preferred method of bolt prep out there? Should a wire wheel be used to smooth the thread surface? Will this improve the tightening force compared to the torque value or is it better to have the rougher surface to make sure they won't loosen up? I wouldn't expect them to loosen with the amount of torque applied but would there be a benefit to smoothing the threads?
While I am asking noob questions, would it be worth it to add hardened washers to the head or main bolts? I see minor indentations in the heads and main caps from the bolts being torqued down so would the addition of hard washers give the bolt heads a smoother ride against the cast iron? It would be cheap to do, but should it be done? and would there be a benefit on a stock, or close to stock, rebuild?
it dont hurt to chase the threads with a bottoming tap, but better yet if its in your budget replace the head and main bolts with new ARP bolts then your not dealing with 40 year old fasteners that have been heat cycled a bazillion times, if your doing a rebuild, definitely replace the rod bolts with arp and resize the rods.
I seriously doubt the bolts in my engine have been compromised by heat cycles or age and I am not building a boulevard bruiser but a cruiser. I just might get a set of new rod hardware though because they seems to be the most abused. And the rods themselves will be checked to see if they need to be re-sized.
That is what I have always done Eric. I have reassembled enough engines to say I am experienced but not enough to say I am good at it. I am not wondering if they factory hardware is up to the task. Just wondering it it is worth the extra effort to spend a little more time prepping them. Will the added washers give more consistent torque values across the bolts? Will smoothing the threads let the bolts tighten better before they reach proper torque? If it is good for ARP hardware, is it good for the factory hardware? I am not expecting ARP type improvements, I won't need that. Is it worth $5 dollars to try and improve what is already there?
Do not use washers with the stock bolts. IMHO, if they were required they would have had washers from the factory. There is a difference in taps for thread chasing/cleaning and tapping. If you run a tap down the holes you remove metal weakening the threads. If the bolts are serviceable, just clean them off and follow the assembly procedures for torqueing.
Depends on your definition of "worth it". ![Big Grin](https://classicoldsmobile.com/forums/images/smilies/biggrin.gif)
For any stock or mild improvement build, just cleaning and reassembly per factory procedure is fine - light coat of oil on the threads (don't want to hydrolock in the hole!) and a good coat of oil under the head, smooth application of torque. As long as the fastener engages smoothly there won't be a problem with the torque readings. If it's actually rough due to burrs or a cracked thread, then something should be done.
Adding hardened washers isn't a bad idea, but need to make sure they don't cause any interference and there's still enough thread engagement (there should be!).
Felpro style head gaskets can also give a lot of room for error on mild builds.
Something I have to continually remind myself is that newer stuff, and nearly all aftermarket stuff, is always built to be "better". More precise, more repeatable, more accurate, etc. The kicker is those improvements may be entirely worthless for a particular situation. Like putting a 500lph fuel pump on a 300 hp engine. So while there are updated practices that are better, the "better" may just be wasted.
This is one of the reasons I am wondering about adding washers. The ARP fasteners utilize them. They also use rolled threads which are much smoother than typical cut threads. I guess this is the reason for my questions. Can anyone give me a reason NOT to add washers and smooth the threads on the factory fasteners?
The aftermarket bolts have a more generous radius on the underside of the head. The washers have a chamfer on the ID that provides clearance for this radius so it doesn't bottom in the hole in the heads. The factory bolts don't have this and thus don't need the washers. Keep in mind that every washer not used on a car results in significant cost savings over the production life. The larger radius is incorporated to reduce stress concentrations, which is really only important if you are running cylinder pressures much higher than stock. For a stock or near-stock rebuild, the original bolts are fine. If spending money on ARP bolts helps you sleep better, go for it, but you'll still be using the stock bolts at the locations that need the studs for accessory mounting.
You should remind yourself that aftermarket stuff is always ADVERTISED to be "better", othewise there would be no need for you to buy it. Whether or not it really is "better" in a specific application depends on the particulars of the application.
I was super impressed with the "steel" main studs that came with the CAT brand main girdle. Snapped right off before coming tight. Among this bullsnort is the actual photo
http://www.ebay.com/itm/Oldsmobile-M...zRpTKg&vxp=mtr
Quite an "upgrade" over the factory fasteners, which were OLD and DIRTY and had HEAT CYCLES on 'em. The CAT brand hardware will never know that sort of abuse!
4 Barrels of Laughs
Location: I moved to pittsburgh so I can be near Primantis
Its been a few years(decades) since I screwed on an Olds head, but only a few weeks since I screwed on *a* head, so these comments are general rules of thumb:
1) unless you have reason to believe the bolt was damaged, re-use. A bolt, is essentially a spring and its elasticity allows the components to move around (and move they do) yet keep a good chomp on the seal. when not tempered or physically damaged, they are pretty resilient. Olds used a fairly arcane torque spec for decades, then near the end increased it dramatically. I question if that was because they went to tty bolts (below) which are not re-useable.
2) if the motor the bolts came from was destroyed by high heat, i.e. a coolant loss demo derby situation, discard all parts, salvage nothing.
3) never reuse 'torque to yield' (tty) bolts....replace. TTY specs, if they chose not to explicitly list the bolt as such are generally 'torque plus some final angle' (which means you put it together with different tools anyways)
4) never add a washer to a bolt that did not have one from the factory or in its package, if ARP comes with a washer, use, if factory did not - do not add.
5) not so much head bolts, more intake, but GM liked to indicate bolts that were tempered for even more heat with a raised circle around the grade markings. (not a 100% rule as I have found) but take an olds small block, the intake bolts near the exhaust crossover (and hence hotter) bear this marking.
6) if the bolt extends into a water jacket, use sealer on the threads and under the head (rare)
7) if the bolt is blind (just a tapped sealed hole) then use oil on the threads to resist heat galling and oil under the head to prevent false torque readings.
8) any washer used with a bolt MUST be of equal or higher hardness grade
9) to get a better seal, sneak up on the final torque in stages, a fairly decent rule of thumb is 50% final torque, then 75% final torque, then final torque and repeat 2-3 times in the pattern. IT takes a while, but you feel so ninja if someone is watching, like you really really know what you are doing ;-)
10) is it mandatory to chase/clean threads if loctite was used, a damn good idea if sealer was used, and somewhat optional if just oil was used. I have a brass wheel on the grinder and clean every bolt I ever use.
11) please do not use any form of anti seize on an engine bolt unless some oddball instruction from the factory tells you to.
Oldsmobile NEVER used a torque-to-yield bolt in a cast iron V8. The increased head bolt torque corresponds to the change from 7/16" to 1/2" head bolts, which corresponds to the change from solid to windowed main web blocks. The lightened 1977-later blocks required the larger bolts and higher clamping force to ensure head gasket seal.
Oldsmobile also NEVER ran any head bolts into the cooling jacket on 1964-1990 motors. In fact, the only bolts on an Olds motor that are "wet" are the two that hold the t-stat housing and the four large ones on the water pump.
Hi Joe,
I'm installing an Edelbrock Performer intake on my 68' 455 block with C heads. Sounds like you're saying none of the intake bolts go into water jackets, so therefore no need for bolt sealer. Is that correct? Also, should some bolts have sealer to prevent oil wicking up to the top? Thanks
Hi Joe,
The major manufacturers "should" be using much more anti-seize; they don't because they don't care how hard the machinery is to service once the warranty runs out, and the cost of materials and labor to apply anti-seize at the factory is more than the cost to not use it and accept a few fastener problems during the warranty period. (And some of those failures can be blamed on the technician, who "eats" the additional labor time.)
RAMBOW
May 27th, 2017 06:11 AM
