having starter trouble need help
Old August 19th, 2019 | 06:19 PM
Logan Cope's Avatar
i have a 73 cutlass supreme with a 455 and every time i crank the car over the starter lets out an awful screeching noise and will get slower and slower and completely drains my battery with in a few key turns i have no clue whats wrong with it im new to working with oldsmobiles please help
Old August 19th, 2019 | 06:36 PM
Sounds like it needs a rebuild or replacement.
Old August 19th, 2019 | 06:38 PM
Logan Cope's Avatar
its brand new i just got it a couple days ago
Old August 19th, 2019 | 07:02 PM
stellar's Avatar
what did the old one do?
Old August 19th, 2019 | 07:09 PM
Its not unheard of to get a bad starter. Have double checked clearances between the starter drive and flexplate or flywheel?
Old August 19th, 2019 | 07:13 PM
Logan Cope's Avatar
it was cracked
Old August 19th, 2019 | 07:14 PM
Logan Cope's Avatar
and i have checked that there was space but i have not measured the space
Old August 19th, 2019 | 07:23 PM
There should be about .030 ,a paperclips clearance in between the point of the starter drive gear and the valley of the flexplate teeth when they mesh. Did you use knurled bolts? Is the starter a high torque factory?
Old August 19th, 2019 | 07:25 PM
Logan Cope's Avatar
i did not use knurled bolts
Old August 19th, 2019 | 07:35 PM
You need knurled American course thread bolts, not metric. They align the starter to the block, plain bolts allow the starter to twist.
Old August 19th, 2019 | 07:37 PM
Logan Cope's Avatar
ok thank you ill get some and try them and see if that fixes the problem
Old August 21st, 2019 | 06:17 PM
rocketraider's Avatar
Oldsdruid
You should be able to find the starter bolts at any parts store if you didn't save the originals.
Our young friend is only 18. Help him like you wish someone had helped you when you were 18.
Scut
September 5th, 2019 01:05 PM
Apollo
June 7th, 2018 08:55 AM
Salmonking
June 14th, 2011 10:20 AM
navvet
May 23rd, 2011 02:49 PM
marzgtp1
May 3rd, 2011 06:32 PM
Quick Reply: having starter trouble need help
