having starter trouble need help
Old Aug 19, 2019 | 06:19 PM
Logan Cope's Avatar
i have a 73 cutlass supreme with a 455 and every time i crank the car over the starter lets out an awful screeching noise and will get slower and slower and completely drains my battery with in a few key turns i have no clue whats wrong with it im new to working with oldsmobiles please help
Old Aug 19, 2019 | 06:36 PM
Sounds like it needs a rebuild or replacement.
Old Aug 19, 2019 | 06:38 PM
Logan Cope's Avatar
its brand new i just got it a couple days ago
Old Aug 19, 2019 | 07:02 PM
stellar's Avatar
stellar
what did the old one do?
Old Aug 19, 2019 | 07:09 PM
Its not unheard of to get a bad starter. Have double checked clearances between the starter drive and flexplate or flywheel?
Old Aug 19, 2019 | 07:13 PM
Logan Cope's Avatar
it was cracked
Old Aug 19, 2019 | 07:14 PM
Logan Cope's Avatar
and i have checked that there was space but i have not measured the space
Old Aug 19, 2019 | 07:23 PM
There should be about .030 ,a paperclips clearance in between the point of the starter drive gear and the valley of the flexplate teeth when they mesh. Did you use knurled bolts? Is the starter a high torque factory?
Old Aug 19, 2019 | 07:25 PM
Logan Cope's Avatar
i did not use knurled bolts
Old Aug 19, 2019 | 07:35 PM
You need knurled American course thread bolts, not metric. They align the starter to the block, plain bolts allow the starter to twist.
Old Aug 19, 2019 | 07:37 PM
Logan Cope's Avatar
ok thank you ill get some and try them and see if that fixes the problem
Old Aug 21, 2019 | 06:17 PM
rocketraider's Avatar
Oldsdruid
You should be able to find the starter bolts at any parts store if you didn't save the originals.
Our young friend is only 18. Help him like you wish someone had helped you when you were 18.
Scut
Sep 5, 2019 01:05 PM
Apollo
Jun 7, 2018 08:55 AM
Salmonking
Jun 14, 2011 10:20 AM
navvet
May 23, 2011 02:49 PM
marzgtp1
May 3, 2011 06:32 PM
