Harmonic balancer
If you're not afraid of using an aftermarket balancer, this one looks close to original and likely will function and won't break the bank. I have no experience with the aftermarket stuff. Unless you want to spend over $100 or more for a SCAT or other "performance" balancer. Someone used to advertise rebuilding the rubber, but I forgot who.
https://www.ebay.com/itm/122046767506
I used the Dorman 594-117 on the 455 I rebuilt. It worked well.
https://www.oreillyauto.com/detail/c...er/doe0/594117
Interesting. Be aware that the auto parts stores will match prices to local competitors. It's a craps shoot as far as which parts store has the best customer service. I generally stick to O'Reilly's because Auto Zone and Advanced Auto Parts are staffed by pimply teenagers that don't know anything about cars.
I've always thought on an Oldsmobile the balancer has to match the rotating assembly. Ie, harmonic balancer, crank and flexplate/flywheel should all match. So no 455 balancer on a 425 or 400. Of course if everything is new and aftermarket you have to send it out to someone who knows what they are doing ON AN OLDSMOBILE to balance the entire assembly.
Chevy doesn't balance the same way and does not need everything to be balanced together.
I found having had the balancing done on my 425, that it was one of the most important things I had done to my engine. It sings like a sewing machine. Smooth as silk. I am sure it contributes to the longevity of the engine.
As an alternative to buying a new aftermarket part, consider having an original rebuilt. I used Damper Dudes in California a few years ago to rebuild the original on my '69 350. Turn-around was 1 week at a cost of about $100. Came back cleaned, painted, sleeved and new rubber. Looked new and has performed great with no drama. I considered just buying one of the aftermarket replacements at the time but I'm extremely glad I didn't.
