Goodies for 455
Goodies for 455
What up Olds Family I hv a 72 Cutlass Holiday Coupe equiped with a 1975 455 with J heads and th400 tranny as far as I know motor is all factory my rear end is original non posi 72 Cutlass friend of mine suggested some Keith Black Pistons what model # do I need? I hv original intake and carb don't wanna race just make a statement every know and then and still catch out to Vegas in a Jiffy Thanks
I moved your post to its own thread. Hopefully now you will get better coverage.
FWIW, I used the TRW L2323F pistons in my 455. If you aren't going to race your car seriously then I suggest using stock or TRW pistons. They are priced reasonably.
Take a step back. Before you worry about pistons, look at the big picture. What are your goals for this engine? What is your budget? You need to make sure that all the components are matched for the operating range you intend. For example, high compression pistons are a waste of money if you still have the J heads and stock cam. Frankly, I'd worry about the heads first, then intake and exhaust improvements, THEN compression.
Dual exhaust always helps wake up the 455 too.
Just make sure your starting with a good foundation, have it magna-flux tested first. The keith blacks (prt#kb866) they run about $440 but like joe said the smog heads are going basicly restrict what ever good they do. And depending where you stay I know myself and j-chicago have g heads for sale. Either way post pics of the build.
Crazy88
April 9th, 2019 06:55 AM
