G and GA Heads
Old Nov 30, 2019 | 10:10 PM
78Delta's Avatar
G and GA Heads
Is there any call for these heads? 455 Big Block G and GA heads? I have a chance to pick up a set.
Old Dec 1, 2019 | 03:32 AM
rob1960's Avatar
They're decent heads for having rather large combustion chambers(I think they're around 80ccs) but like the earlier C & E heads they can have 2 different valve sizes depending on what they originally came on. 442s & Toros usually got the big valves. The big valve GAs were also used on '72 W30s
Old Dec 1, 2019 | 06:07 AM
With the exception of the 1968-69 D heads, all BBO heads are 80-ish CC chambers. The D heads are 72-ish. As-cast chambers can vary and are usually 2-4 CC larger than the blueprint specs.
Old Dec 1, 2019 | 07:40 AM
cutlassefi's Avatar
That is correct. Not sure where the continuous misinformation is coming from though.
JRDRAGTOP
Sep 17, 2017 04:24 AM
69CutlassAlex
May 19, 2013 11:50 AM
olds4life
Dec 25, 2012 12:56 AM
Olds_71_442
Dec 4, 2012 10:25 AM
Young Man
Dec 30, 2010 01:40 PM
