G block 400...
Old Jun 13, 2012 | 04:33 PM
Stevec's Avatar
G block 400...
Just curious, a 1968 g block 400 has a bore of 3.870. Has anyone ever bored one out to 4.000 or more? Can it be done?
Old Jun 13, 2012 | 04:50 PM
allyolds68's Avatar
No one has ever posted that they did. There's an old thread on ROP about it. Rumour has it the cylinder walls are pretty thin. The casting is different for a 455. A 400 G doesn't have just have the same casting with thicker sleeves
edit:
here's the thread:
http://www.realoldspower.com/phpBB2/...ckness&start=0
and a couple people said they have
Here's another one on Classicolds:
https://classicoldsmobile.com/forums...red-455-a.html
Old Jun 13, 2012 | 06:14 PM
Run to Rund's Avatar
A good auto machine shop can sonic test the walls for thickness and tell you what the safe overbore would be. then you will probably have to buy custom pistons like CP, which you might be doing anyway if you are looking for the max bore size and power.
Old Jun 14, 2012 | 03:54 AM
Stevec's Avatar
Thanks guys...
TicTocTach
Jun 16, 2015 04:03 PM
stonecad
Feb 11, 2014 02:02 PM
chrisneu68olds
Dec 30, 2011 10:17 AM
sbFALL63
May 28, 2010 05:45 AM
