Fuel pump Qs
Fuel pump Qs
The fuel pump on my 60 98 394 is acting up.
Anyone know why it would be leaking oil out what looks to be a small vent hole in the pump body, above the bottom diaphragm? There's a square recess in the body facing the right side of the car, and what looks like a vent hole in the back left corner.
I took the pump out this morning to clean it and see what was wrong -- both diaphragms look fine. After I re-installed it, the car started and ran fine for a little while but soon stalled and would only start and stay running with the choke closed. It seems like there's no fuel in the carb body -- the accelerator pump doesn't squirt gas when you open the butterflies.
I pulled the top fuel line connection and cranked the engine -- got some fuel but not what I'd call a lot and not a steady stream. Is this normal?
Could I have installed the pump with the lever in the wrong position? Is the end of the arm supposed to go above or below the eccentric in the case? I made sure the ignition rotor was pointed toward the rear of the car when I pulled the pump, as instructed by the previous owner.
Service manual is on the way, so fewer questions soon.
Many thanks in advance,
Steve
Steve
Nor Cal Andy
Mar 29, 2012 07:27 PM
stlbluesbrother
Mar 21, 2011 03:24 PM
