Front crank case leak?
Old Jan 17, 2014 | 01:20 PM
66Jetstar's Avatar
Ever since I got my '66 Jetstar 88, it leaks oil out of the bottom-front part of the engine. It doesn't do it constantly, only for a day or two after its been run. I did a little research and I think it could be the front crank case gasket? I found a guy to fix it, but I also want to put a different cam in this engine (425) so would it make sense for him to do both since he'd be working around the same place?
Old Jan 17, 2014 | 03:01 PM
m371961's Avatar
Most likely front seal. All gasketing and seal in that area would be disturbed during cam replacement, so do it all at once. Also use sleeve on vibration dampner seal. Your guy should know this.
Old Jan 17, 2014 | 03:14 PM
66Jetstar's Avatar
Ok thanks. I've done a bunch of research on figuring out whether my engines bank angle is 39 or 45, but I'm still not sure which one it is. Also do I need to replace my lifters or anything else with a new cam?
Old Jan 17, 2014 | 03:26 PM
Yes, new lifters always go on a new cam.
Old Jan 17, 2014 | 06:37 PM
m371961's Avatar
and new chain and gears
Old Jan 17, 2014 | 06:41 PM
66Jetstar's Avatar
im sorry but I don't know what new chain and gears means
Old Jan 17, 2014 | 06:43 PM
Grace Stinespring-Welch's Avatar
might as well put new valve seats in while it is down.
Old Jan 17, 2014 | 06:56 PM
Octania's Avatar
Uhm, NYET
that's a whole 'nother can of worms. When last heard, a OIL SEAL REPLACEMENT which could be really simple, has turned into pulling the front cover, dropping the oil pan, and now the intake is off to replace the lifters.
At no time did this "mistasell" into taking the heads off.
Restraint, please.
peruse this
https://classicoldsmobile.com/forums...placement.html
Aron Nance
Sep 22, 2012 06:50 AM
Lady72nRob71
Jul 3, 2011 01:39 PM
68Tom
Nov 8, 2010 02:14 PM
jensenracing77
Sep 4, 2009 05:39 PM
Snowdog
Apr 11, 2009 11:43 AM
