first start
#42
As others have said it still sounds like you need to dial in the timing. It shouldn't take 3 hands. Snug down the distributor until it will still turn but is not loose. Start the car and run at high idle until it is warmed up and you do not need the choke. Choke should be open. Reduce engine speed to the lowest level the car will run. Slowly rotate the distributor. If the engine Rpm starts going up and running smoother reduce idle speed. Keep going until the engine starts to run poorly and then back it up again to the point where it runs the best. If the engine stumbles and dies rotate back to the point it last ran and restart the car. Slowly rotate the distributor the opposite direction. This will get you close.
#43
wow, fast responses.
the engine will not idle, even with the idle screw all the way in..but luckily I can get 3 hands, so I can get that taken care of. good to know its timing and not carb related.
so, if I take anything away from this project, its this: if you are looking at intake manifolds, and you KNOW you will have distributor clearance issues, don't just think "ahh well, I'll just pull the distributor out and reset the drive gear on the cam, once I get close I'll have it!" because it's just not that easy.
#44
okay, it will start, idle/run for a few seconds, then it backfires (out of the carb) and dies.
I've adjusted the timing all over the place, and this seems to happen no matter if where it is.
the timing order is correct.
also, I've been adjusting the timing with the vacuum advance line plugged. should I have that hooked up or not?
and when I do get it to run, I adjust the timing with the vacuum advance unhooked, with the RPMs above where the mechanical advance is, right?
#45
Ok let's go over a few things. Did you get full voltage at the coil? Did you get your carb rebuilt? What rpm are you trying to set timing and what setting are you using? Are you sure the firing order is correct? Yes, the timing is set with the vacuum advance line disconnected and plugged.
#46
okay. when I'm not cranking, there is 3.7 volts at the coil...the engine has ran while not on the starter, I have ignition.
no, I haven't rebuilt the carb, but I did confirm its function on a friend's truck.
yes, I'm sure the firing order is correct.
#48
depending on where I ground out, I get 3.7-4.5 volts.
when cranking, I got full battery voltage.
I thought that the engine cuts down on voltage to the coil while running (via the resistance wire) to keep from burning the points up??
#52
When I installed the distributor, I had the valve cover off and put #1 to the compression stroke, and did the firing order off of that. The distributor is a points unit with a pointless kit, and an MSD blaster 2 coil, and won't clear the offy intake. Today I will completely revise the system to make sure the firing order is right, and it isn't 180 out.
The power steering pump shaft and pulley have a notch in, neither has an outward notch. It's nothing like the harmonic balancer.
A pointless kit is not stock and most require the removal of the resistor wire.
#53
We'd need to know the exact make and model to be able to look up the instructions.
The Crane sensor that came on my 350 requires the original resistor.
We return again to the place we always end up: Without getting good information, we can't provide good information.
#55
Okay, so let's bark up a different tree.
You have a car that runs, but doesn't idle, with a used, non-rebuilt carburetor that you observed to work well on the vehicle it was on before.
I agree with the others that you HAVE to get this engine times correctly.
Connect timing light, vacuum gauge, and tach, place each in safe place, clean and mark balancer slot and timing tab with chalk, paint, or whatever you'd like, so you can see them clearly, start car, grab timing light, point and shoot, slowly drop RPMs and watch advance drop, then raise RPMs to about 3,000 and watch the advance climb. Set to about 35°BTDC at 3,000 RPM. Then see where the timing goes as you reduce the RPMs again. Watch it so you can note the advance at the lowest RPM you can get.
You have a new, non-factory cam, so you don't have any timing guidelines for this engine - you will have to establish your correct timing from scratch, and probably recurve the mechanical and vacuum advance of your distributor to get the car to run right.
But first, let's get the timing in the ballpark.
If it won't idle with the timing set to 35° at 3,000, then connect the vacuum advance and see if it idles better that way.
This is going to be very hit or miss because, since you have a new cam, you're making up your timing specs as you go along.
#56
Eric, I'd leave the vacuum canister disconnected as it will advance the timing way to far and he will get detonation. Also once it's set he needs to make sure that he gets no advance past 3000 rpm. It's a modified points distributer not an hei.
#57
Okay, but with a cam, he may need extra advance at idle to idle smoothly.
I agree that this may require distributor adjustments to get it dialed in, but hooking the hose up and seeing whether it helps will at the least be instructive, and may move us further along.
#58
okay, so today I fooled around with the timing some more, and it seems no matter where I put it it does its start-putt-putt-BOOM-stall routine. I will take a video and post to explain what I mean.
is 0 degrees straight up on the balancer, or at the beginning of the timing tab?
all vacuum lines are plugged, except for the one going to the distributor, and the brake booster.
#60
ok, worked on the car some.
if I back the distributor off, it will run without backfiring, but will not idle. at a certain point, the engine will no longer crank over. it will pop and fire all the way in this range, if I hold the throttle open it will run.
going the other way, eventually the engine will backfire. somewhere in the middle I got it to run okay with the idle screw all the way in, with a piece of tape jammed between the adjuster/throttle lever. but I can't seem to find that sweet spot again. it wasn't what I'd call a smooth idle, it sounded like it was way retarded.
when I installed the cam timing gears, I used the old timing chain, which was replaced when the entire motor had a stock-rebuild maybe 40k miles ago, so I did not account for stretch and installed it with both dots straight up. I know some people install them with both dots facing each other, but since I had set the motor to TDC before this, and both dots were up, I put it back together this way.
I think its running lean, (305 carb on cammed 455 problem) and tomorrow I'm going to see if I can find the sweetspot where it would idle roughly, and mess with the mix adjustments on the carb to see if I can smooth it out.
if that doesn't work, I'll borrow a carb from my friend (stock pontiac 400 qjet) and see if I can get better luck with a carb set up for a larger motor.
here is my cam.
here is my cam.
#61
http://www.youtube.com/watch?v=Xvq-a...ature=youtu.be
it does run great, just doesn't want to idle where the carb does.
I don't have a tach to check my RPM.
#63
I know the video is crappy, if it was any longer it wouldn't upload.
I'll see if I can do better tomorrow in the light.
I took the throttle return springs off, and set the throttle a little ahead of the idle screw. tomorrow I will take the spring off of the adjuster screw, screw it in far enough that it will idle, and see if I can tune it effectively.
the water pump is leaking, so I've got to deal with that too.
#65
I took the water pump off, and decided to look at the timing without the pump in the way.
its WAY to the passenger side of the vehicle (retarded?) and when I tried to advance it to the driver side, the engine died.
#69
So if you used your old chain and installed the dots straight up.....is it not possible that the slack was on the back side of the cam. Meaning the crank would turn several degrees before the cam started turning. This would effectively be the same as installing the cam a tooth or 2 off. Eric & Eric your thoughts?
#74
Oh for the love of Pete.
Nobody measures anything in thirds of an inch.
And, I'm sorry, but my photographic memory isn't that good.
If you are going to be adjusting the timing this way, please either get a dial back timing light, get a timing tape, or just measure and mark your balancer so that you can read off the timing past the normal markings.
The measurements are:
20°=28.8mm
30°=43.3mm
35°=50.5mm
40°=57.7mm
50°=72.1mm
20°=28.8mm
30°=43.3mm
35°=50.5mm
40°=57.7mm
50°=72.1mm
emarkay
December 8th, 2004 08:23 AM
