Finally getting my BB
Old Jun 26, 2009 | 12:56 PM
csouth's Avatar
I know I've read all the threads and stories about SB being able to put out equal power if built right, but its the torque that gets me. After riding in a friends 442, it can't compare. I have a strong '69 350 in my car that runs great, but you guys know what a difference torque makes. I was able to find a 68 Toro motor for a good price. I was also able to get my engine sold for almost what I paid for the 455. I'll be pulling my engine and picking that one up this weekend. They guy also threw in a set of Comp Cams roller rockers with guide plates and pushrods. Is there anything I need to be look out for with this motor? I do know I'll have to change the oil filter housing. I'm sure I'll be back asking questions in the next cpl days... Wish me luck.
Old Jun 26, 2009 | 01:06 PM
csstrux's Avatar
LUCK LUCK LUCK congrats on the find.
Old Jun 26, 2009 | 01:34 PM
csouth's Avatar
Thanks... I saw the car the engine was pulled from, had about 60k on it. I plan on changing all the gaskets. Installing a Moroso oil pump and pick up along with a new water pump and timing chain. I know doing all of this before install would make life a lot easier..LOL
Old Jun 26, 2009 | 01:52 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Chad, I have a 425 block that needs an overbore here if you want it.
It's a 45 degree lifter bank so people have been avoiding it like the plague.
I can't even get a $50 spot for it, while Std bore 455 blocks are going for $100 on Craigslist.
Old Jun 26, 2009 | 02:13 PM
csstrux's Avatar
I'll have to drop a line next time I'm in the area...but its been a long time since I've been that way. Rates have been in the gutter in chi town lately. All over actually. On a high note I just got my dually running again but that thing gets HORRENDOUS mileage.. Assuming I ever find an early 60's b body I can afford a 425 would be a sweet motorvator
how is this for sad, I have an86 supra I want to put a small block in. I can get a sbc 350 tbi with a 700r4 with an extra tranny for scrap rate...got no money
another guy has a bbo 455 a poncho 400 and a couple th400's for scrap...got no money
At least the guys I normally would be running my tail off for by now are starting to call, will be with them for the first half of the week any way, and all of the third week of july. hopefully more.
Old Jun 29, 2009 | 11:50 AM
AJCDFIN's Avatar
Hey; nice find, may have big valves and steel crank
Old Jun 29, 2009 | 01:14 PM
citcapp's Avatar
Chad,
Hope things get back on track for you soon. Sad thing when you can't pick up on the good deals when they come along. How come this never happens when a guy has a few extra bucks in his pocket?
Old Jun 30, 2009 | 12:06 PM
csouth's Avatar
I picked my 68 Toro motor Sunday. My return trip was not without adventure as I had a blowout on my truck during the return trip. I'm going to pick up a gasket set, clean it up and start pulling it apart pretty soon. BTW, anyone know if it is necessary to change the pushrods if using the original cam with roller rockers? Asking because the guy included a new set of CompCams rollers with guide plates with the motor. He didn't have the pushrods though.
Old Jun 30, 2009 | 04:14 PM
citcapp's Avatar
Yes you need to replace the pushrods with the roller rockers. They are usually purchased a part of a kit. Make sure you get the right ones for the 455. Check the compcam web site to get the right ones
Old Jul 1, 2009 | 06:15 AM
csouth's Avatar
I did see them on the site last night. I didn't know if I needed theirs or any hardened pushrod for a 455?
Old Jul 1, 2009 | 08:04 AM
citcapp's Avatar
They are not the stock length. If you still have questions on the correct length. call the comp cam help line they will fix you up
I forgot to ask did the roller rockers and guild plates come with the required rocker studs, they need to be replaced as well
Old Jul 1, 2009 | 08:31 AM
csouth's Avatar
I'll give Comp Cams a call and get the specs on the pushrods that cam with the set... Thanks
Old Jul 1, 2009 | 12:43 PM
csouth's Avatar
Question
Can anyone recommend a good gasket kit? Maybe with part #?
Old Jul 2, 2009 | 08:29 AM
88 coupe's Avatar
Junior Member
Originally Posted by citcapp
........ call the comp cam help line they will fix you up ........
Originally Posted by Comp Cams
........ A large number of variables are involved in determining the correct length pushrod for your application. Pushrod length is affected by any one or all of the following:
• block deck height
• head deck height
• head stud boss height
• rocker arm brand/design
• cam base circle size
• lifter design/brand/pushrod seat height
• valve stem length
Don’t assume anything in determining the right pushrod for your new engine. A pushrod that fits one engine may not necessarily work in another. Any number of items can be different on your engine, requiring you to use a different pushrod length. Following the steps below will streamline the pushrod selection process, ensuring that you get the right parts the first time ........
http://www.compcams.com/information/Products/Pushrods
Norm
Old Jul 2, 2009 | 10:13 AM
csouth's Avatar
I'm going to pusrchase a pushrod lenght checker, it seems like a wise investment....
Old Jul 2, 2009 | 10:27 AM
citcapp's Avatar
Good call, will save you some trouble
bonezarally
May 14, 2011 01:25 PM
CreekBandDad
Jul 15, 2007 02:01 PM
Moofinator
Ninety-Eight
28
Jun 4, 2007 09:13 PM
muttmeg
Ninety-Eight
Apr 21, 2007 09:26 PM
WesB.
Apr 14, 2007 09:16 PM
