file fit rings
file fit rings
well, I am saving the original pistons for re use . The 4.125 bore is just that so am sure that in conjunction with the bore looking ok ,the pistons being ok and this being a street only build , I require a hone and new rings ,What size gap do you recommend .Currently ,using the existing rings placed at the base of the bore ,I am getting a 55 thou gap.Presumably, i want somewhat less than that ?
paraphrasing
> what brand of ring do u recommend?
> what gap do you recommend ?
cheers
mike
paraphrasing
cheers
mike
Different brand rings, may have different specs. They will have the info in the box thet come in..055 is a lot, new ones will be more like 25-28 on top one. Also if you use different pistons, some require more than stock ones.
