file fit rings
Old Aug 6, 2008 | 12:14 PM
geckonz08's Avatar
file fit rings
well, I am saving the original pistons for re use . The 4.125 bore is just that so am sure that in conjunction with the bore looking ok ,the pistons being ok and this being a street only build , I require a hone and new rings ,What size gap do you recommend .Currently ,using the existing rings placed at the base of the bore ,I am getting a 55 thou gap.Presumably, i want somewhat less than that ?
paraphrasing
> what brand of ring do u recommend?
> what gap do you recommend ?
cheers
mike
Old Aug 6, 2008 | 02:19 PM
442Harv's Avatar
Different brand rings, may have different specs. They will have the info in the box thet come in..055 is a lot, new ones will be more like 25-28 on top one. Also if you use different pistons, some require more than stock ones.
Old Aug 7, 2008 | 10:00 AM
Run to Rund's Avatar
New replacement rings will give about .018" to .020" gap, first and second ring, about what you will want. Oil rails will have more gap. If your bore is worn, the gap will increase by dia x pi.
davebw31
Jul 14, 2013 04:59 PM
724drcutlass
Site Help
Jun 15, 2012 07:00 AM
My442
Jun 18, 2011 03:52 AM
