F85 Dyno results
Old Aug 11, 2013 | 03:13 AM
FinOldsMan's Avatar
F85 Dyno results
I whent this 66 f85 to dyno an it has 455 engine. Very poor condition.
411Nm 2050Rpm and 162Hp 3500Rpm So this engine goes work shop..
Old Aug 11, 2013 | 07:35 AM
Your youtube link is no good.
Old Aug 11, 2013 | 10:09 AM
FinOldsMan's Avatar
I hope that i dont need to use explosives ...
Old Aug 11, 2013 | 01:07 PM
mcalvo's Avatar
The torque is about right but with those HP numbers it seems like a low compression stock motor.
-Michael
Old Aug 11, 2013 | 08:40 PM
FinOldsMan's Avatar
I try fix that youtube link soon.. Abaut that motor i think it dsnt run ewen stock cause stock has over 200 hp, putyeah torque is ok..
Old Aug 12, 2013 | 09:59 AM
FinOldsMan's Avatar
There it goes.. started make a new olds
Old Aug 12, 2013 | 08:30 PM
Mr Nick's Avatar
Is Nm the same as Ft/lbs of torque? 1:1 comparison or no?
Old Aug 12, 2013 | 08:51 PM
young olds's Avatar
No its not 1:1, It is newton meters(metric) of torque vs our foot pounds(standard) of torque
Old Aug 13, 2013 | 11:25 AM
FinOldsMan's Avatar
411Nm is 92,396lbs..
I blow the motor and there is 40cc pistons ...
It has G heads
Some good i found is "N" crank..
and cam vas some.. hmm i dont know.. not original cam.. it vas CFD 401384
Sylinders vas good condition and standart 4.125 I try to find a flat top pistons for 4.125 so i dont have to over bore that block..
Old Aug 13, 2013 | 04:16 PM
svnt442's Avatar
411nm it 303.1Ft lbs.....seems quite low to me.
You won't know for sure about the block needing to be bored until it's disassembled and the bores checked for scratches, out of round and taper (from top to bottom) so don't go buying pistons just yet. Don't buy the bearings either until you have the crank checked either and you may need to have it turned o the mains, rod journals or both...or neither. Get it apart and to a competent machine shop and then start ordering parts, not the other way around or you could be in trouble trying to swap parts out if for nothing else but extra time.
Old Aug 13, 2013 | 08:34 PM
FinOldsMan's Avatar
Old Aug 13, 2013 | 08:38 PM
FinOldsMan's Avatar
Yeah you are right.. ill do.that... to day i take off mains,crank and pistons and all that goes.. then cleaning up an then scratch test..
Old Aug 14, 2013 | 09:57 AM
FinOldsMan's Avatar
Some horrible oil **** on the heads..
Old Aug 14, 2013 | 10:45 PM
svnt442's Avatar
Wow.
slam1918
Nov 19, 2013 04:56 PM
ah64pilot
Jun 28, 2012 10:44 AM
Joffroi
Mar 21, 2012 02:07 PM
J-(Chicago)
Nov 3, 2007 12:30 AM
olds307owner
May 17, 2007 07:48 PM
