Exhaust Manifold doughnut gasket
Old Jun 21, 2009 | 10:28 AM
toneypenna's Avatar
Problem with 455 using w/z exhaust manifolds. I have always put the exhaust pipes up without a gasket and never had a problem. This time the left bank has a slight leak and I thought a doughnut gasket would help. The problem is I cant find one the right size. All the gaskets I have that came from 455 gasket sets have doughnuts that measure 2 3/8 " and larger at the metal flange that goes in the manifold. Felpro 60241 says its 2 1/8 but actually is
2 3/8". Fel pro tech line gave me # 60360 that is 2 1/8 ID, I need 2 1/8 OD.
Anybody out there know a part # or have any thoughts on this
Thanks,
Jim
Old Jun 21, 2009 | 10:49 AM
citcapp's Avatar
The Olds W/Z manifolds do not use donut gaskets. A trumpet flange formed by an exhaust shop seals to the manifold without a gasket of any kind. If the angle of the pipe is wrong and the trumpet flange is to small you will get a exhaust leak
Old Jun 21, 2009 | 01:28 PM
toneypenna's Avatar
Thanks for the reply.
What you describe is what I have allways done. I have had these pipes on and off at least 6 times since I finished this car. As I said this time for some reason I have a slight leak only on the left side and thought a gasket might help.
Thanks again
Jim
Old Jun 21, 2009 | 05:22 PM
Bobsw32's Avatar
BobsW32
I had the same problem and didn't want to take them off so I used some muffler cement on them when I put them together......Fixed the leak
DLaz70OLDS98
Oct 19, 2013 10:18 AM
waterzap
Sep 9, 2013 09:02 AM
aussiemobile
Feb 15, 2013 07:31 AM
Big red72
Jan 29, 2013 07:53 AM
67cutlass67GS
Jun 24, 2012 01:51 PM
